Free Shipping at Buy.com!
FREE Personal Trainer Program
This is a discussion thread titled "2006 Tundra Double Cab- Subwoofer help...", within the Audio & Stereo forum, part of the Technical & Vehicle Assistance Forums category.
  #46 (permalink)
Old 02-20-2007, 07:25 AM
Dealer : David Maus Toyota Scion
lost1700's Photo Albums
Last Online: 01-02-2008 06:18 AM
lost1700 is on a distinguished road.
Default Re: 2006 Tundra Double Cab- Subwoofer help...
cool, you might want to check into trying to make all three subs have equal airspace. So, you got about .6 cubes in the storage compartment divided by two, gives you .3 cubes for each sub. So in the jack compartment I would make the fiberglass shell to be .3 cubes, that way everything matches and the response from each sub should be about the same.
CELLY, Can't wait to see how it looks, where in Orlando are you?
  #47 (permalink)
Old 02-20-2007, 08:34 AM
Dealer : Mic Mac Motors
Celly's Photo Albums
Last Online: 12-10-2007 10:07 AM
Celly is on a distinguished road.
Yeah, I need to do a lil more measuring, but the numbers I'm seeing in WinISD is making me think I can get away with chambers and be happy.
I'm East Orlando -- Waterford / UCF area.
  #48 (permalink)
Old 02-20-2007, 11:48 AM
Dealer : Team Toyota
Cajun93's Photo Albums
Last Online: 08-05-2008 05:28 PM
Cajun93 is on a distinguished road.
Ya'll don't forget about the little 8in Tang Band driver.
http://www.partsexpress.com/pe/pshow...number=264-854
2006 Tundra Limited DC TSS pkg (Ph. Grey)
  #49 (permalink)
Old 02-20-2007, 11:54 AM
Parts Express:TANG BAND W8-740C 8" SUBWOOFER
Wow, for the Price, that's hard to beat. Still a lil deap @ 121mm (~4.75in) -- But for 40$, It'd be worth messing around with.
We should start a thread/faq of available subs for this...
  #50 (permalink)
Old 02-20-2007, 01:58 PM
Dealer : Ira Toyota of Manchester
1sty's Photo Albums
Last Online: 06-15-2008 12:08 AM
1sty is on a distinguished road.
Won't fit in the storage compartment of the DC. Atleast mine certainly didn't
  #51 (permalink)
Old 02-20-2007, 04:39 PM
What is WinISD? I go to UCF and live in Winter Springs (seminole county), right down the street.
  #52 (permalink)
Old 02-21-2007, 11:19 AM
Yeah, there are mixed reports about what people say will fit or not.
I realized this has to do with 2 things, how deep you cut your speaker rings, and the Height of the speaker.
The Plastic shroud (bottom of the seat) over the storage compartment leaves very little room.. So if you have a high excursion or tall speakers you'll loose about a half an inch in mounting depth becuase of how deep you need to bore out the holes so the speaker doesn't bottom out on the seat.
WinISD is a nifty lil piece of software that helps you see the response that you'll get from a particular setup. Granted there ate 100's of other variables that go into the way your system will sound, WinISD gives you a lil bit more of a warm fuzzy and helps you see potential problem areas before you start.
  #53 (permalink)
Old 02-21-2007, 04:41 PM
Sounds like a pretty cool program. Is it free or did you have to buy it?
  #54 (permalink)
Old 02-21-2007, 11:44 PM
There is a free and pro version.
LinearTeam
  #55 (permalink)
Old 04-02-2007, 10:04 AM
darkmerlin's Photo Albums
Last Online: 04-04-2007 01:49 PM
darkmerlin is on a distinguished road.
Has anyone used any of those pioneer shallow subs? i think i could fit two tens with two of those. They are only 2 1/2 inches deep. Any thoughts?
  #56 (permalink)
Old 04-07-2007, 12:31 PM
Dealer : Red McCombs Toyota
samotoxracer21's Photo Albums
Last Online: 12-29-2007 07:09 PM
samotoxracer21 is on a distinguished road.
Has anyone looked into putting an L5 or L7 solo barric kicker with the baffle? they only require min. .33 cu in and the depth is at 4 3/4. Was just checkin out what other speakers would fit back there.
  #57 (permalink)
Old 04-07-2007, 09:10 PM
banshee4785's Avatar
Dealer : Performance Toyota
banshee4785's Photo Albums
Last Online: 09-04-2008 07:04 PM
banshee4785 is on a distinguished road.
check out my pics-now understand I had these left over from another project.-it was not the best sealed thing-they thing is it did work very well-I didnt need it to hit real hard-and it is only an 8- But I will say just for an 8 inch speaker it hits--
2008 Black sr5 crewmax 5.7 with graphite leather
Previous daily driver
03 4x4 access cab 4x4, -T100 ext cab 4x4 silver...now The t100 retired to the farm mostly
  #58 (permalink)
Old 04-08-2007, 08:53 PM
Dealer : Hellman Toyota
2005 Toyota Tundra
sic402's Photo Albums
Last Online: Today 04:04 AM
sic402 is on a distinguished road.
L5's and L7's have the same mounting depth, but i believe the diameter on the L7 is pretty big, and the L5 is big enough where you will have to hammer out the side of the compartment in order to make it fit.
  #59 (permalink)
Old 04-11-2007, 02:29 AM
Does anyone know the measurements of the compartment under the rear passenger seat on the drivers side? thanks
  #60 (permalink)
Old 04-11-2007, 07:42 AM
Puffnstuff's Avatar
Puffnstuff's Photo Albums
Last Online: Today 06:16 AM
Puffnstuff is on a distinguished road.
I considered mounting 8" solobarics under the seats however the tray on the left passengers side has a sloped side to the rear which detracts from mounting space and depth. If you knew a welder you could modify that compartment and make it more squared and deeper which would accomodate more sub. I don't know why toyota wasted so much open space under our trucks like that. I would've loved to mounted my s10l52 under the rear seats but it was just too large so it sits in a vented box in the back seat for now.
Similar Threads for: 2006 Tundra Double Cab- Subwoofer help...
2006 Tundra Double Cab Fog Light Install Instructions yodapug 1Gen-Tundra 20 02-09-2008 06:28 PM
Tundra Access Cab V6 vs. Tacoma Double Cab Intensity 1Gen-Tundra 21 09-10-2006 08:30 AM
2006 Tundra Double Cab -Need biggier Rear View Mirror hathaway65 1Gen-Tundra 8 07-30-2006 05:27 PM
Toyota Stages World Premiere of New Tundra Full-Size Pickup at 2006 Chicago Auto Show nhparrot Toyota, Scion & Lexus News 0 02-09-2006 04:35 PM
Tundra Access Cab vs. Tacoma Double Cab planetdell 1Gen-Tundra 134 11-12-2004 07:29 PM
