the tacoma kit is very similar but you are going to have to cut and connect some wires
WIRING INFORMATION - TOYOTA / T100 / 1998 / Remote Start
12volts white - white/red + ignition harness
Starter black + ignition harness
Second Starter Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Third Ignition Accessory blue/red + ignition harness
Second Accessory Keysense
Power Lock red/wht or blu/wht - low in driver kick panel Notes: Lock relays located in drivers kick panel. Test with doors closed, or both pin switches held in.
Power Unlock red/yellow - low in driver kick panel Notes: Lock relays located in drivers kick panel. Test with doors closed, or both pin switches held in.
Lock Motor Unlock Motor Parking Lights+ green at fusebox
Parking Lights- red/black steering column Hazards Turn Signal(L) Turn Signal(R) Reverse Light
Door Trigger black/white - wht plug in fusebox
Dome Supervision Trunk/Hatch Pin Hood Pin Trunk/Hatch Release Power Sliding Door
Factory Alarm Arm Factory Alarm Disarm Disarm No Unlock Tachometer black AC igniter, check conn Notes: The check connector is located on the front passenger inner fender well next to the underhood fuse box. Wait to start
Brake Wire green/white + drivers kick panel Parking Brake
Horn Trigger green/red - steering column Memory Seat 1 Memory Seat 2 Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A Part #: N/A Notes:
Smart Starter Kill Relays: Not Available
