This is a discussion thread titled "What size spacers for comps?", within the Audio & Stereo forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-28-2007, 04:47 PM
Dealer : David Maus Toyota Scion
lost1700's Photo Albums
Last Online: 10-20-2008 01:06 PM
lost1700 is on a distinguished road.
Default What size spacers for comps?
I have a set of 6.5" comps w/ a 3" mounting depth I want to install, does anyone know what size mdf spacer ring I will need. I have a guy building me a box, I can just have him cut me some spacers too.
THanks
Old 02-28-2007, 08:04 PM
Default Re: What size spacers for comps?
anybody? please...
Old 02-28-2007, 10:00 PM
Dealer : Harrelson Toyota
RBeesburg's Photo Albums
Last Online: 05-14-2007 10:39 PM
RBeesburg is on a distinguished road.
I used a pair of 6.5 inch CDT compoments. I modified the factory speakers to act as a mount. I cut away the paper driver and broke away the "ribs". Then I used a router to cut down the ridge that runs around the outer edge. Then the replacement speaker can be glued and screwed into the modified OEM speaker. The nice thing is that the speaker is then pround of the metal door skin and mounted into the cabin as far as possible. I will post some photos.
I would imagine you or your sub box guy could do this without much trouble.
Old 03-01-2007, 07:32 AM
I will have to check that out, thank you.
Old 03-01-2007, 08:53 PM
Dealer : Mic Mac Motors
Celly's Photo Albums
Last Online: 12-10-2007 11:07 AM
Celly is on a distinguished road.
eD Makes a set of rings for a Scion tC. Apprently they work really well on the tundra. You can probably email them and see how thick they are..
... Oh, and when you find out the answer can you PM me? I have a set of CDT's I'm installing in 2 weeks .. So, I need the same thing ...
Old 03-02-2007, 07:21 AM
the ones for the tc are 3/4", the ones for the xb are 1.5". Is it the ones for the tc or the xb?
Old 03-02-2007, 10:17 AM
I'm almost positive it's The tC Spacers -- Reguardless, the proper answer is 3/4" of an inch.. Just found some old posts on here about it.
Old 03-03-2007, 10:51 PM
mit42ls's Avatar
Dealer : Fred Anderson Toyota of Sanford
mit42ls's Photo Albums
Last Online: 07-30-2008 09:40 PM
mit42ls is on a distinguished road.
I installed CDT EF-61CFi's and had to build 1.5" MDF rings/baffles glued together to install them in my front doors. I also had to do a pretty good window track mod to about an inch. That was 3/4" for the rings and 3/4" for the baffles. I have pics in my gallery to look at...
Old 04-09-2007, 06:07 PM
murfdaddy's Avatar
2005 Toyota Tundra,
2001 Lexus IS300,
- Other - 1989 Toyota Ext. Cab
murfdaddy's Photo Albums
Last Online: 09-09-2008 01:35 AM
murfdaddy is on a distinguished road.
how did you get the door panels to go back on after making baffles like that? I made some similar and the door panel wouldn't snap back on
05 Tundra SR5 2wd • 2.5 Hoes • Total Chaos UCAs • JBA Headers • 285/75/16 MT/Rs
Searching for rear 4.30 gears. PM me if you've got some for sale.
Old 04-11-2007, 02:00 AM
Dealer : Landers Toyota Scion North
txcomp's Photo Albums
Last Online: 12-06-2007 01:09 PM
txcomp is on a distinguished road.
I used one piece of 3/4" MDF and one piece of 1/4" ABS when I built my buildouts. I also modded the window track to get the CDT HD 6 1/2's in there.
I also had a problem with the door panels fitting back on and ended up having to "rotate" the speaker in the mount (up and back I believe) to get the door panel to clear. The cone of the 6 1/2 STILL hits the back side of the door panel when I'm really pushing it sometimes though.
Tim!
2006 Tundra 4x4 Access Cab Off-Road
2001 BMW 325ci
USACi Technical Director
MSF and Riders Edge Instructor
Old 04-11-2007, 08:51 AM
Puffnstuff's Avatar
Puffnstuff's Photo Albums
Last Online: Today 10:12 AM
Puffnstuff is on a distinguished road.
When I mounted my eclipse se8365's in the back doors I also used the factory speaker baskets. Like you guys I cut out the poly speaker and then shaved the spiders from inside the basket. I soldered the new speaker wires to the factory connetors inside the basket and reused the factory plug on the door. I mounted the new speakers to the baskets without cutting anything away off the top and the door panels went right back on. The tweeters are against the door speaker grill but they don't buldge out and it places the speakers as far forward as I could get them. They sound so much better than the stock speaker because I needed highs and mids to project into the back on not bass since the sub is handling that for me. Actually the stock components up front sound really good and I'm going to keep them for now. I know you guys complain about paper speakers but my dc came with polypropelene speakers and they sound alright.
Similar Threads for: What size spacers for comps?
Front Spacers Question? Taco man Tacoma 4 12-17-2006 11:09 PM
Lift Spacers, Lift Spacers and More Lift Spacers Snowballer 1Gen-Tundra 3 11-15-2006 08:54 PM
Best looking tire size on Tundra... look at the pic here Agent WD-40 Tires and Wheels 29 02-24-2006 03:24 PM
Oddball Tire Size? Rick Tires and Wheels 1 10-01-2003 09:32 AM
New 1.5 Cornfed Spacers IowaBoy Suspension & Axle 2 07-02-2003 09:32 PM
