Bed Rust Recall??
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Like Tree1Likes
Thread: Bed Rust Recall??
  1. #1
    Join Date
    May 2003
    Location
    twin cities
    Posts
    114
    Liked
    4 times
    Rep Power
    690
    Default Bed Rust Recall??
    I know many of you are having the same problem with the bed rusting from below where the x-members are spot welded. Toyota is well aware of this problem. When I had my frame replaced, the service manager asked me to come back so they could get pictures. He said Toyota corporate is "watching" the problem and 2 mechanics at the dealer have the same issue.
    Mine is a 2000 with 255000 miles on it. Yes I'm in MN and it's old and high miles. But....... I have zero rust anywhere else on the truck. It gets constant underside washes in the winter, has been "Herculined" and hase been covered with tonneau all its life.
    I am NOT looking for anyone who does not have this issue to chime in (as in other threads on this issue) with: maybe it was in an accident, should have washed it more, bed was replaced with aftermarket, ..........etc. This is a known defect. What I would like to see is members with this issue to post pics (I'll have mine up soon). If we do that, and all of us call Toyota, they may be motivated to at least handle it on a case by case basis. The voice of many will be heard.
    Toyota issues many "double secret" recalls; which if you complain enough, the vehicle is fixed. The prime example is the front brake rotor warping on 2000-2003 Tundras & Sequoias. Ask the service manager:
    Hey are there any TSB's on my truck?
    Ran the VIN and nothing comes up.
    What about the front rotors that keep warping and vibrating?
    Hmm, I haven't heard anything about that.
    My understanding is the rotors and calipers were undersized causing overheating/warping and Toyota is replacing them with bigger ones.
    Boy that doesn't ring a bell.
    What about TSB BR004-002?
    Ohhhhh, that one. Let's get you scheduled for a brake upgrade.
    So guys (and gals), let's escalate this!!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    May 2009
    Location
    Nelsonville, OH
    Posts
    110
    Liked
    23 times
    Rep Power
    23
    Default Re: Bed Rust Recall??
    I have rust over the wheel wells...and some underneath, although I do not think the bed has been perforated yet. I like the logic, though. That bed sat in contact with that frame...I would think that it's gonna rust just as bad.
  4. #3
    Join Date
    Jun 2010
    Location
    Chesterfield, VA
    Age
    20
    Posts
    688
    Liked
    222 times
    Rep Power
    8897
    My bed is rusting through on both sides between each wheel wells, and I have two small ones that haven't rust through yet.
    I will monitor this.
  5. #4
    Supporter ricqik's Avatar
    Join Date
    Feb 2000
    Location
    Twin Cities, MN
    Posts
    1,475
    Liked
    42 times
    Images
    4
    Rep Power
    4574
    i have a '00 with 233k. ive had my frame replaced. i put on herculiner on my truck way way back in it's early life. the liner is holding well but u can definately see that porforation type rust is trying to blister thru the herculiner, evident bcuz of the bulges.
    '00 tundra
    '06 sequoia
    '98 forester
  6. #5
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,221
    Liked
    416 times
    Images
    25
    Rep Power
    24550
    Quote Originally Posted by ferris buehler View Post
    I doubt it. You're in the rust belt and you have some rust on the bottom of the bed of an eleven year old truck. You'll find the same thing under the beds of any make of pickup truck. That particular construction technique is problematic, unfortunately, as the two pieces of sheet metal around the spot weld provide an ideal environment for corrosion. But this is not the same as a rusted out frame, which is a safety problem.
    Your best bet - I may do this on my '03 - is to take the bed off, have the corroded areas sand-blasted and then paint immediately with an appropriate coating.
    jack mccarthy likes this.
  7. #6
    Senior Contributor jack mccarthy's Avatar
    Join Date
    May 2002
    Location
    boston, ma
    Posts
    5,801
    Liked
    990 times
    Images
    1
    Rep Power
    348765
    Quote Originally Posted by mibro View Post
    I agree, it's not a safety issue, so no liability on their behalf. I plan to wait till they pull the bed for the frame coating procedure. A couple places told me they drill out the corroded torx bed bolts and replace them.
    At that point in time, I'll probably remove the bed, cut out the bad sections and weld in some new metal and paint it. Bedliner is going over it, so who cares how it looks.
    "Laughter is the best medicine. But, if you're laughing without any reason, you need medicine."
    How to perform a search: Select "Advanced Search" -> Choose the "Single Search Content Type" tab, Enter the "Keyword", Select Search in Forum "1st Gen Tundra", Search by Prefix "any thread", Show results as: Choose either "Posts" or "Threads", then click on "Search Now".
  8. #7
    Supporter kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    44
    Posts
    2,697
    Liked
    807 times
    Images
    27
    Rep Power
    231947
    Same problem here. I keep my '02 looking immaculate. When I brought it in for the spare tire holder inspection the service manager told me the truck looked better than some 2008's that come through there, yet the bed still has rust where you described.
    I brought it to a local body shop that I use when I need it and they told me to do it right they would have to cut out the entire bottom of the bed and replace it. They also said it would be cheaper to buy a replacement bed if I could find one. I asked about the cutting out and patching idea and they said it would just put off the inevitable. I scraped it with a wire brush and took an angle grinder to it with a sanding wheel and patched some with bondo and repainted. That was a couple of years ago and it's held up pretty good for now.
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
  9. #8
    Join Date
    Feb 2000
    Location
    Twin Cities, MN
    Posts
    1,475
    Liked
    42 times
    Images
    4
    Rep Power
    4574
    We're not talking about just surface rust here. Blister rust r signs of porforation. Mine has it next to the wheel well, the floor of the bed n on the bed screw area. Just a matter of time b4 my bed flies off n pegs someone behind me. Pray its not one of u who think its not a safety issue.
    '00 tundra
    '06 sequoia
    '98 forester
  10. #9
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,221
    Liked
    416 times
    Images
    25
    Rep Power
    24550
    Quote Originally Posted by ricqik View Post
    My brother works in Ghana. The roads there are generally in a terrible state. The Ghanaians know who's responsible for this. The British, who didn't build the roads right before they left Ghana for good, fifty four years ago.
  11. #10
    Join Date
    May 2003
    Location
    twin cities
    Posts
    114
    Liked
    4 times
    Rep Power
    690
    Thread Starter
    As I said in the first post, I'm not looking for reponses like "you are in the rust belt, it's going to happen". No it shouldn't have to. I will post pictures of the underside of the bed and cab. CLEAN, no rust, except where the cross memeber spot welds are. My friends' Chevys and Fords are not doing this; other areas yes, but the structural welds are fine.
    How is it not a safety issue? The bed's structural supports are deteriorating, as well as the attachment points. Would you want to be behind me when the bed eventually blows off or a load of concrete blocks falls through because the cross members are no longer supporting? The comment is irelevant, since Toyota is finding it intersting enough to document and follow the issue. They obviously see a potential problem.
    Please post pictures, and Toyota can be directed to this thread.
    Here's my rustbelt truck:
    And here's the bed rusting. Notice how there is NO rust where the bedliner scraped off from loading building materials:
    TOYOTA ARE YOU LISTENING??
  12. #11
    Join Date
    Jul 2005
    Location
    New England
    Posts
    1,221
    Liked
    416 times
    Images
    25
    Rep Power
    24550
    You have a high mileage, eleven year old truck. You're in the rust belt and you're what, four years and at least 100,000 miles beyond the limit of the corrosion warranty? You know the truck is not in a roadworthy condition and you're still driving it. And if someone is injured that will be Toyota's fault?
  13. #12
    Join Date
    May 2002
    Location
    boston, ma
    Posts
    5,801
    Liked
    990 times
    Images
    1
    Rep Power
    348765
    It would be a safety issue if the bed completely let go. Realistically though, it'll be one or two bolts at a time. Knowing Toyota, they'd probably state it was your lack of responsibility for not taking care of the issue when the first bolts broke away just to be a jerk about it and avoid liability. I agree that they should step up and take care of the issue, but I don't think their lawyers would agree. JMHO
  14. #13
    Junior Member robbergeron23's Avatar
    Join Date
    Dec 2005
    Location
    holland, ma.
    Age
    49
    Posts
    59
    Liked
    0 times
    Rep Power
    664
    with 176,500 miles on my 2001, mine is doing the exact same thing. No matter what anyone says, that should never, ever happen
    on any brand truck. Terrible metal Toyota used, well after they had the frame issues on their mid eighties trucks. Unbelievable.
  15. #14
    Join Date
    May 2002
    Location
    boston, ma
    Posts
    5,801
    Liked
    990 times
    Images
    1
    Rep Power
    348765
    I'll add it to my NHTSA complaint that I'm doing for the steering column shifter breaking away from the steering column. Complained to Toyota about that today; as expected, they won't help out unless an accident occurs since they'd be liable.
  16. #15
    Join Date
    May 2009
    Location
    Portland, TX
    Age
    32
    Posts
    404
    Liked
    14 times
    Rep Power
    2315
    Did Toyota step up their rust proofing at some point in the Gen 1 trucks? I see no major rust in any areas of my '06 and I'm really hoping it never occurs!
    -Wes
    2006 Toyota Tundra, Double Cab, 4.7L, 4WD, Silver Sky Metallic
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
