Access cab window latch broken - Page 12
+ Reply to Thread
Page 12 of 16 FirstFirst ... 278910111213141516 LastLast
Results 166 to 180 of 235
Like Tree55Likes
Thread: Access cab window latch broken
  1. #166
    Junior Member yotabangin's Avatar
    Join Date
    Jun 2012
    Location
    Round Rock, TX
    Posts
    157
    Liked
    40 times
    Images
    3
    Rep Power
    871
    Default Re: Access cab window latch broken
    installed mine today, took about 10 minutes. Not bad for 10 bucks. I like em. Besides both my old latches were broke so these do the job. Only concern is they may not lock quiteeee as tight so i will see if any water gets in or anything. I think I could shave down in a spot and make it latch tighter. We will see but overall I am pleased. Thanks man
    tundra3400 likes this.
    2003 Access cab step side / bilsteins all the way around / OME 886 springs / camburg UCA and uniballs / removed sway bar / toytec AAL in the rear with 2 inch blocks and hellwig 1250 helpers / toytec 3 degree shims / streetacos carrier bearing drop 2 1/4inch / Pro Comp alloys 16x8 and firestone destination all terrains 285/75/r16 / Alpine type R 12' sub and deck
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #167
    Join Date
    Feb 2012
    Location
    Taylorsville, UT
    Posts
    70
    Liked
    11 times
    Rep Power
    274
    Quote Originally Posted by yotabangin View Post
    The black soft aluminum arm on the truck side of the entire latch assembly often gets bent outward slightly during installation. Open the window, and grab that arm with your hand and give it a couple of yanks inwards. It will snug the windows up and they will close tighter than before. Just don't over do it, it doesn't take much.
  4. #168
    Join Date
    Jun 2012
    Location
    Round Rock, TX
    Posts
    157
    Liked
    40 times
    Images
    3
    Rep Power
    871
    sweet I will try that, thanks man.
  5. #169
    Join Date
    Feb 2012
    Location
    Taylorsville, UT
    Posts
    70
    Liked
    11 times
    Rep Power
    274
    Did that work for you?
  6. #170
    Join Date
    Jun 2012
    Location
    Round Rock, TX
    Posts
    157
    Liked
    40 times
    Images
    3
    Rep Power
    871
    trucks getting a timing belt and water pump etc done right now.. got it back today and it was leaking at the thermostat housing... so will see what tmrw brings. Im not too worried about the windows tho, im sure they are fine
  7. #171
    Join Date
    Feb 2012
    Location
    Taylorsville, UT
    Posts
    70
    Liked
    11 times
    Rep Power
    274
    Sounds good. Let us all know in here when you snug them up. I'm curious on how they turn out.
  8. #172
    Join Date
    Oct 2012
    Location
    Georgia
    Posts
    24
    Liked
    12 times
    Rep Power
    3
    I installed mine this past weekend, they worked as advertised, no issues, though I think a hair tighter closure would be perfect. I did try to bend the base in a little to tighten things up, but I don't think that is the answer. Seller is honest and helpful and I'm happy with the product.
  9. #173
    Rookie Bighorn's Avatar
    Join Date
    Sep 2011
    Location
    Wisconsin
    Posts
    13
    Liked
    5 times
    Rep Power
    0
    Funny (not for me) story.
    Last year i was hunting in Wyoming with my brother, many miles off the beaten path.
    Last day ended up locking my keys in the truck. No spare set (big mistake).
    After pondering the situation, decided that breaking a rear window to access the cab was my best option.
    My brother had a 4 way lug wrench available. With much trepidation (my brother couldn't even watch), I hauled off and gave the rear window a massive hit.
    The wrench bounced off the glass. No breakage.
    It did however unlatch the window. I was able to reach through and saw the plastic latch open with a meat saw. A stick to push the lock release, and I was home free.
    Got home and replaced the cut latch with a stock Toyota unit.
    Leason learned? Spare keys are a good thing.
    2003 Tundra
  10. #174
    Junior Member MetroMan's Avatar
    Join Date
    Jun 2002
    Location
    Agoura Hills, CA
    Posts
    82
    Liked
    49 times
    Rep Power
    5717
    After one of my rear latches broke I did a search and came across this thread. I ended up buying two Billet Pivots from redruM69 (eBay name is dasherdeals) and fixing the broken one and some preventive maintenance on the other. Looking at his video and hearing the concerns with the windows not closing as tight as before I figured I would take the latches off of the truck to install the new pivots. It is very easy to do. The plastic trim pops off enough that you can remove two 10mm bolts. Then the Philips head screw on the window. Once on the work bench it is easy to push the pins out far enough to remove the old pivots and install the new ones. Once everything was installed the windows closed as snugly as before. I can see if you tried to do this job while the latch was on the truck it would be easy to bend something causing them not to close as tightly as before.
    Many thanks redruM69 for a great and very fair priced product.
    2001 Tundra SR5 AC Original Owner, 85K Miles
    Mods; Tacoma TRD wheels with Michelin LTX MS2, Double Din Kenwood Nav Unit with Sirius, Power Antenna, Back-Up Camera, Parrot Bluetooth, Electronic Day/Night Mirror with Temperature & Compass, '04 Taillights, Steering Wheel Modified by CarsDream.com, BlackVue DR500GW Dash Cam
    2012 BMW 535I M-Sport 25K Miles
    2001 Porsche Boxster S Original Owner 25K Miles
    2007 Mini Cooper S 30K Miles
    1997 Porsche 993 Turbo - SOLD
  11. #175
    Join Date
    Feb 2012
    Location
    Taylorsville, UT
    Posts
    70
    Liked
    11 times
    Rep Power
    274
    Hey guys, long time no talk!
    Since making these available, I have now sold over 10,000 units! They have been a huge success, and just about everybody has been extremely pleased with their windows that work. The reason I say "just about" is because I have had a small handful of complaints. Most of these complaints were they fit a little loose due to machining inconsistencies, or that they were not as thick as the original plastic part, and looks weird.
    Due to unpopular demand, I have made a new prototype pivot. This one costs me a bit more to make, but I should be able to price them the same. They are now machined more accurately in the holes, and the entire pivot is shaped the exact same as the original piece, thickness and all.
    I had 12 units made to test the waters, and would like 5 beta testers from this forum to test them out. Send me a PM with your address, and I will send a single pivot for you to test for free. I'll toss a classic replacement pivot in the package as well, so you can compare the 2.
    Only the first 5 PM's will get this for free. Post a "PM sent" reply in this thread so that I don't get flooded.
    When you get them, post your results with a PM and in this thread.
    Thanks guys!
    JJ
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Jahrey78 likes this.
  12. #176
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,238
    Liked
    3033 times
    Images
    47
    Rep Power
    162515
    Quote Originally Posted by redruM69 View Post
    Thanks guys!
    JJ
    NOW you're talkin'!!! Those look great!
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  13. #177
    Supporter Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    2,141
    Liked
    860 times
    Images
    4
    Rep Power
    41874
    PM sent
  14. #178
    Veteran Member Jimmypop's Avatar
    Join Date
    May 2012
    Location
    Grand Rapids MI
    Posts
    758
    Liked
    791 times
    Rep Power
    79583
    P.M. sent!
    "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." - Albert Einstein
    I don't entirely know what OCD is, but I know it's very fashionable to accuse people of having it if they try and do something properly. -James May
  15. #179
    Junior Member SSizler's Avatar
    Join Date
    Feb 2013
    Location
    Central Iowa
    Age
    55
    Posts
    134
    Liked
    89 times
    Images
    5
    Rep Power
    6867
    PM sent!
    Jim
    2002 Limited Access Cab 4WD - Thunder Grey Metallic - Oak Interior w/Leather Pkg - Auto-Dim Mirror w/Compass & Outside Temp
    TRD Off Road Pkg - All Weather Guard Pkg - Towing Pkg - LSD - Line-X - 2006 TRD Wheels w/ LT265/75R16 Cooper ST Maxx Tires
    Softopper - Rear Bilstein 5100's - Poly Steering Rack & Sway Bar Bushings - Original Frame - 101,000 Miles - Protected with Zaino Products
    Pending Mods: King Coilovers - TC UCAs -Wheelers 3 leaf add-a-leaf - Rear Brake Proportioning Valve Relocation -ORS High Angle CV Boots
    N-FAB 3" Nerf Steps - Replace Leaky Steering Rack
  16. #180
    Join Date
    Jun 2002
    Location
    Agoura Hills, CA
    Posts
    82
    Liked
    49 times
    Rep Power
    5717
    I installed two of your original units and they were great. If you send on one, I compare it to you original ones and let you know if there is a difference. The first generation ones were so good I believe it will be hard to improve on them. PM sent.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
