Access cab window latch broken
+ Reply to Thread
Page 1 of 16 12345611 ... LastLast
Results 1 to 15 of 235
Like Tree55Likes
Thread: Access cab window latch broken
  1. #1
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,534
    Liked
    961 times
    Images
    38
    Rep Power
    42221
    Default Access cab window latch broken
    Hello, my access cab window latches on both sides are now broken and i am looking to fix them. i have been searching around and found that i can get the replacement from Toyota but they are still made of plastic and will most likely brake again. i was wondering if anyone knows if someone makes aluminum latch arms to replace the plastic ones.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member oofy15354's Avatar
    Join Date
    Sep 2009
    Location
    Massachusetts
    Age
    22
    Posts
    1,378
    Liked
    276 times
    Images
    21
    Rep Power
    13237
    Default Re: Access cab window latch broken
    We used to have John at JSI Motor sports but they went under. There is no one else that I know of unfortunately. I managed to get mine from Josh before he disappeared
    Remmy700P and cpearson817 like this.
    2001 Black AC V8 4x4
    Current Mods: 5100s on 4th Notch, Diff Drop, Poly Rack Bushings, Recon Tailgate LED Bar, Edelbrock Exhaust, Hankook Dynapro ATM 265/70/R16, Blacked Out Emblems, Color Matched Mirror Caps, Bumpers and Front Grill, Skid Row Skid Plate (Thanks to four_by_four), Full Blue LED interior lighting, Herculiner Bed Liner, Kobalt Low Profile Tool Box, Smitty Built Rear Shackle, Walmart Front AUX lights, JVC Headunit, Kicker Front Components, Pioneer Rear Speakers, Magnefine Filter, Viper Remote Start, Single in-Dual out 2.25in Exhaust
    Thanks to Rust: New Frame, New Calipers, New Rear Axle, Sway Bar End Links, Tailgate Straps, Patched Bed Floor
    Quote Originally Posted by italiantundra88 View Post
    dave, every one has a weekness, yours is just any work on your truck
  4. #3
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    48
    Posts
    8,282
    Liked
    3074 times
    Images
    47
    Rep Power
    162515
    Quote Originally Posted by oofy15354 View Post
    ...I managed to get mine from Josh before he disappeared
    Same here. They're a far more robust part. Someone with access to a CNC milling machine will step up and fab up some more of these.
    cpearson817 likes this.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  5. #4
    Join Date
    Sep 2009
    Location
    Massachusetts
    Age
    22
    Posts
    1,378
    Liked
    276 times
    Images
    21
    Rep Power
    13237
    I used to have access but figured people would rather buy from a legit company. Now that he's gone, I don't have access to that CNC anymore. I probably do somewhere at my university but I haven't discovered where yet. I plan on making some once I get that sorted out but I'll have to make some friends first
  6. #5
    Senior Contributor tundrunk's Avatar
    Join Date
    Nov 2009
    Location
    check the bar or liquor store
    Posts
    6,288
    Liked
    2679 times
    Images
    216
    Rep Power
    255259
    ? That sucks. I had mine wrapped in zip ties as reinforcement before I got aluminum ones.
    "Drunk by noon but that's okay, I'll be President some day"
    - Sublime
  7. #6
    Veteran Member jjjackies's Avatar
    Join Date
    Aug 2009
    Location
    southern, California
    Posts
    713
    Liked
    19 times
    Images
    110
    Rep Power
    2475
    found these on craigslist there asking $25.00 a piece hope this helps you out
    heres the link
    Toyota Tundra vent window latches 98-04
    Ivan Stewart Conversion, Trd Eaton Lsd, Trd Ceramic Headers, Ipt Transmission, Trd Catback
    Race Runner Saws,
    Total Chaos Ucas, Bhlm, V-leds, Muth Mirrors, Q-Logic Sub Box
    Future Mods
    Trd Supercharger, G57 Deavers, Retrofit Headlights
    Saw Rear Shocks, Upgrade Stereo, Etc, Etc.
  8. #7
    Join Date
    May 2005
    Location
    Tempe, AZ
    Age
    76
    Posts
    1,670
    Liked
    87 times
    Rep Power
    14577
    I talked to Remmy awhile back about getting an extrusion made and cutting latches to size. I didn't hear back from the supplier I contacted, but am trying to contact another one. I'll probably have to dig out my old drafting supplies to make a drawing before doing it. They my not want to deal in very small quantities. They consider 1,000lbs a small job. We'll see if they are hungry?
  9. #8
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,534
    Liked
    961 times
    Images
    38
    Rep Power
    42221
    Thread Starter
    oofy15354; yea i noticed that jsi motorsports disappeared. it a shame. if you do get get access to a CNC machine and make a few of them let me know.
    tundrunk; the zip ties are a good idea for now thanks.
    tempetom; 1000lbs small? lol. ok if they do consider it let me no
  10. #9
    OBT
    OBT is offline
    Veteran Member OBT's Avatar
    Join Date
    Sep 2010
    Location
    south, Louisiana
    Posts
    715
    Liked
    89 times
    Images
    5
    Rep Power
    28166
    I would also be interested in getting some of these if someone gets the chance to make some.
    First gen member #31 White, 02 Tundra, 3.4l V6, 6000k hi/lo 35watt HIDs, 30" single row led light bar, 285/75/16 Fierce Attitudes, 2 1/2inch skyjacker level kit, add a leaf, 5% tint on brow, 35% fronts, 20 over 20% backs, LED swap, pioneer 2300DVD touchscreen
    Still waiting on a duramax
  11. #10
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    896
    Liked
    163 times
    Images
    48
    Rep Power
    12661
    A few years back there was another member who had some machined and began selling them, but because Josh complained about having to complete, this guy stopped selling them. I have a set that he sent me in case I ever needed them. For the life of me I cannot remember his name, maybe some of the old members my recollect. I do know that a few of the posts were deleted because the discussion got pretty heated. :-) I'll have to drink a few beers and put my thinking cap on and see if I can find some old info.
    In the meantime, Anamouse made his own, check this thread. Rear window latch broken
  12. #11
    Join Date
    May 2007
    Location
    RB
    Posts
    138
    Liked
    48 times
    Rep Power
    1907
    Someone get the CAD file, email it to me. I have 2012 LT on my system right now, I'll see what I can do at work.
    No promises though, our CNC guy is backed up.
    arseum and cpearson817 like this.
  13. #12
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    896
    Liked
    163 times
    Images
    48
    Rep Power
    12661
  14. #13
    Join Date
    Dec 2010
    Location
    Illinois
    Posts
    146
    Liked
    21 times
    Rep Power
    839
    Looks good.... but I can not find him on ebay.
    Quote Originally Posted by kanaduh View Post
  15. #14
    Join Date
    Dec 2007
    Location
    Fairfax, VA
    Posts
    896
    Liked
    163 times
    Images
    48
    Rep Power
    12661
    I found the seller and sent him an e-mail. I see what he says, and update.
    Remmy700P likes this.
  16. #15
    Join Date
    Dec 2010
    Location
    Illinois
    Posts
    146
    Liked
    21 times
    Rep Power
    839
    ^ Thank you! I have two broken latches also. This would be a nice upgrade.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
