Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry Hybrid
Old 07-08-2007, 10:59 PM
ksyrah's Avatar
Dealer : Toyota of Santa Barbara
2004 Toyota Highlander,
2007 Toyota Camry HV White on tan leather
Last Online: 06-26-2008 10:14 PM
ksyrah is on a distinguished road.
ksyrah's Photo Albums
Default Fuel Grade
Anyone expermented with 89 or 91 to see if it affects mileage with the hybrid. I know it does with my Highlander but I was curious it the hybrid.
Thanks
Old 07-09-2007, 09:32 PM
Dealer : Falmouth Toyota
Last Online: 10-18-2009 08:10 AM
Ed_T is on a distinguished road.
Ed_T's Photo Albums
Default Re: Fuel Grade
I'm on the fourth tank and I filled it with 89 for the first time. The restarts seem easier, and the mileage looks promising so far. I'll post back with the results. Ck out greenhybrid.com for mucho mileage info in their database.
Old 07-20-2007, 09:42 PM
Dealer : Toyota Scion of Orlando
Last Online: 02-24-2008 09:59 PM
LOL TCH is on a distinguished road.
LOL TCH's Photo Albums
I filled up on 91 octane for just one tank and it made no difference in FE. I believe 87 octane is the way to go. Also, I've never had a tank less than 47mpg since switching to 87 octane Shell gas. Post hoc, ergo propter hoc? Try it and see if you get better gas mileage. Just stay away from ethanol. It causes the car to run too rich and kills FE.
Old 08-05-2007, 07:16 AM
Ed_T's Photo Albums
I'm on my second non-consecutive tank using 89, and I'm not seeing an increase in mpg, although the restarts seem smoother as well as engine operation all around.
Old 08-05-2007, 12:22 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Last Online: 10-28-2009 02:33 PM
Jer is on a distinguished road.
Jer's Photo Albums
Okay... wait.. what?!? You're getting 47mpg in a TCH?!?
A right, not a privilege - ΜΟΛΩΝ ΛΑΒΕ
=-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
Old 08-06-2007, 09:39 PM
I've had quite a few tanks above 50mpg and 2 tanks where I went 800 miles. The calculated numbers are always a bit lower of course. Alot of people say that all brands of gas are the same. They say it all comes from the same place and that the only difference is the label on the truck. I have enough miles on the car to know this isn't true. I'm not saying Shell has the best gas, but it does give me really consistent tank numbers. There are alot things you have to do to get 50mpg and where you buy your gas is just one of them.
Old 08-06-2007, 09:48 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
In a Camry Hybrid, right? Not a Prius Hybrid? That sounds too good to be true for a TCH.
Old 08-06-2007, 09:55 PM
The badges say Camry Hybrid all right! I have a friend who drives a Prius and I can't help rubbing it in that I get better gas mileage than he does.
Old 08-07-2007, 12:36 AM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
You have 5 posts so I won't bother trying to find a thread where you've explained how to attain such mpg #'s. Will you give a few pointers here to a fellow TCH owner that might help me get to your economy?
Old 08-08-2007, 08:57 PM
I'll post some thoughts on the 40 mpg?? Tell us how you do it !! thread
-Ed
Old 08-08-2007, 08:59 PM
I"ll post some thoughts on the 40mpg?? tell us how you do it thread.
-Ed
Old 08-08-2007, 09:04 PM
I'll post some thoughts on the 40mpg ?? tell us how you do it thread.
-Ed
Old 08-08-2007, 09:33 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
Sorry for the duplicate post.
Actually, it was a triple post.
Trying to increase that post count, eh?
I'll look forward to your post because being able to break 40mpg for us on an entire tank of gas is quite a challenge let alone the 50mpg you're talking about.
Old 08-11-2007, 08:29 PM
Dealer : Toyota of Naperville
2007 Toyota Camry HV 50th Anniversary,
2006 Toyota Corolla
Last Online: 09-02-2009 01:22 PM
9phil9 is on a distinguished road.
9phil9's Photo Albums
When you fill up the tank, are you filling it 100% with the higher grade, or are you actually just mixing the higher grade with what's left?
If you are like most people, you are probably filling it with about a 75/25 mixture.
So saying the higher grade did/does nothing probably isn't very accurate.
And did you take into account that while you were experimenting with that mixture, the fact that the computer was "learning" to adjust to the higher octane?
I would think that before you make a blanket statement about the higher octane not making any difference, you ought to at least give it a fair trial period starting off at about the fourth full tankful of the higher grade.
By that time the mixture should be better than 95/5 % , and the engine computer should then be able to remap itself, to compensate for the increased timing afforded by the higher octane.
It's worth the thought.
Old 08-27-2007, 06:38 AM
Ed_T's Photo Albums
Re 89 octane I'm 1/4 way through the third consecutive tank and not seeing m.p.g.increase.
When I fill up, the fuel warning light is always on and I've always had to add at least 16 gallons minimum, so I don't think dilution was a big factor.
I'll try Shell 87 next couple of tanks maybe.
Fuel Filter: How to replace and is it hard? nhparrot Engine & Drivetrain 6 04-29-2008 01:33 AM
E85 grooveninja Tacoma 25 02-06-2008 11:39 AM
'04 Sequioa Detonation/Pinging 04sequioa4x4 1Gen-Sequoia 23 11-17-2006 08:58 PM
Valve pinging upon hard acceleration? brtundra 1Gen-Tundra 21 08-14-2006 04:46 PM
Rocket fuel? glenhaven Engine & Drivetrain 5 08-14-2004 12:48 PM
