Programming
I’ve had my TCH for a year and will be taking it for a 32,000Km check in a few days. I’m going to ask the dealer to check the cruise control. Starting up a hill it gets rather aggressive, actually going to a higher speed than what I’ve set. I usually disconnect it approaching a hill. I’m wondering about the engine running when you’re in the “B” position on the transmission. It appears to be a bit erratic. Most times the engine is off as you come to a stop but on occasion it starts up and you shut it off by going to the “D” position. Is there any documentation that outlines how the car is “programmed”?
