Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry Hybrid
Old 09-22-2007, 09:29 PM
Dealer : Toyota of Naperville
2007 Toyota Camry HV 50th Anniversary,
2006 Toyota Corolla
Last Online: 09-02-2009 01:22 PM
9phil9 is on a distinguished road.
9phil9's Photo Albums
Default Can HID's be installed on a TCH ?
I would love to install some HID headlights on my TCH, but I'm afraid they might not work with the DRL's.
Has anyone done this successfully, without damaging the DRL system?
I know the Avalon Limited and the Touring model come with HID's, and the DRL's still function.
So there must be some way to do it.
Old 09-24-2007, 03:29 PM
2006 Toyota Corolla
Default Re: Can HID's be installed on a TCH ?
OK I see that no answers are forthcoming from this forum, so I dug into it another way.
HID's are a simple install on the TCH, IF you have the correct wiring harness.
Apparently you need something special to keep the computer from showing an error when you turn them on.
The genuine MTEC line has just such an install kit for the 2077-2008 Camry.
AND you don't have to worry about the DRL's, because they are on your High Beam circuit, not the Low Beams.
So the DRL's, and the Auto headlights feature will still work as normal.
Plus with the advantage of the HID's drawing only 35 Watts, instead of 55 watts, like the stock Halogens do, the reduced electrical load should help improve your gas mileage too.
(After all, you don't get something for nothing.)
But saving gas will NOT pay for the lights.
So the real reason you install them is for the triple light output, and the longevity of the bulbs.
Old 09-26-2007, 01:54 AM
Dealer : Lynch Toyota of Auburn
Last Online: 02-12-2008 03:20 PM
simplexveritas is on a distinguished road.
simplexveritas's Photo Albums
from my limited experience, you need to put some 55w resistors in parallel to "trick the computer". i put a hid kit from neverburnout in and WAH LAH -- ERROR MESSAGE.
Old 09-26-2007, 10:29 PM
2006 Toyota Corolla
Thanks for the good advice.
In my search for "Correct" information on this conversion, I came across the MTEC line that addresses exactly what you are talking about, by supplying a special ballast that is designed just for the 2007-2008 Camry.
They guarantee "No Computer Error" with their kit.
And they also guarantee lifetime bulbs.
Old 09-27-2007, 02:01 PM
Dealer : Toyota Scion of Hollywood
2008 Toyota Camry HV
Last Online: 09-27-2007 05:39 PM
mina323 is on a distinguished road.
mina323's Photo Albums
SO are you guys doing a straight Plug and Play connection without connecting it to the battery with a harness..?
Old 09-27-2007, 04:21 PM
2006 Toyota Corolla
Of course.
That's why the "Kit" is made especially for the 2007-2008 Camry.
There is no need to do some bungled up amateur wiring job, (Which will for sure void your warranty.) when it's not necessary.
The MTEC kit is a high quality, Japanese manufactured, conversion that is meant for dealers, to offer real (headache free) HID's.
There are plenty of cheap Chinese kits that are made for generic applications that usually end up in disaster, and one very expensive repair at the Toyota dealer later.
And unless you have the correct type of ballast, you will get an error message from your computer when you power up.
Good luck with the cheap kit, but if things go horribly wrong, don't say you weren't warned.
Old 09-27-2007, 05:09 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Last Online: 10-28-2009 02:33 PM
Jer is on a distinguished road.
Jer's Photo Albums
Uhmm... it's not anywhere near as much of a nightmare as you paint it to be. I've used MANY 'cheap Chinese' kits with nothing but success save for one bulb fitment issue.
A right, not a privilege - ΜΟΛΩΝ ΛΑΒΕ
=-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
Old 09-29-2007, 10:59 AM
2006 Toyota Corolla
You used a cheap Chinese generic HID kit, and it didn't produce a computer error code?
Which system/kit number did you buy that allows that?
Old 09-29-2007, 12:14 PM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Every single post here seems like "the Blind, Leading the Blind".
No one gets it here. Aftermarket HID's are not DOT Compliant.
(If yu want HID , just buy a Vehicle that offers OE HID.)
The wow Factor is "wow", but all yu get is a "MESS" of Illumination and this is inconsiderate to other drivers. The Light "cut-off" cannot be controlled. It should not be used other than for "Off Road".
Some people forget that we "Share the Road" , not own it exclusively.
To dispute the above, please offer some REAL technical insight.
And, unfortunately, there's no challenging the facts.
LT
Old 12-27-2007, 06:39 PM
Dealer : City Toyota
Last Online: 06-13-2008 02:59 PM
NO-hp is on a distinguished road.
NO-hp's Photo Albums
Life Tech your 50% right. After market HID's are not DOT approved.
But on the camry they use a lens and not just a reflector to aim the light.
If you look at the stock Camry halogens they have a cut off just like HID equiped vehicles so the light will be in the same place.
2008 TCH Black
2007 H2
2002 F150
1993 F150 Lightning turbo
1967 Shelby Cobra
Old 01-03-2008, 12:24 AM
Installed the MTEC kit yesterday, very nice.
Ordered the 6k lamps, looks like OE!
No CEL.
-Joe
2008 TCH Black
2007 H2
2002 F150
1967 Shelby Cobra
Old 01-04-2008, 10:02 AM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
This isn't a european car,you won't have any error codes if a HID system is installed. No resistors or "black boxes" are needed.
I have both 07 and 08 electrical wiring diagrams in front of me. There are connections to the body ecu,but its for triggering the relays,not for directly powering the bulbs. The relays supply power to the bulbs,relays get power from the battery. So how would there be any error codes?
I can't upload pics @ work,but I'll post diagrams tonight if anyone needs a better explanation.
Old 01-04-2008, 06:21 PM
Eddie's Avatar
Moderator
2000 Toyota Tundra,
Images: 32
I outlined the lowbeam relays and bulbs in red.
See how the main body ECU connects to the relays? Those are the ground terminals for the relays' coils,these are low-current circuits. The ECU does not look for a 55-watt load,hence no difference in operation if a HID ballast replaces the bulb. There's no need for "special ballasts",resistors,etc.
The diagram also shows the highbeam circuit,you can see the DRL relay. According to Toyota it's a solid-state relay,I think it lowers bulb voltage via pulsewidth modulation instead of resistors.
Old 03-23-2008, 10:44 PM
pokerface's Avatar
Dealer : York Toyota
2004 Toyota Highlander
Last Online: 03-23-2009 12:19 AM
pokerface is on a distinguished road.
pokerface's Photo Albums
What about drawing too much power from the existing wires? ie on startup?
I have seen another Camry drive past me on the road with HIDs, it was okay, but not as clean as OEM solution.
Old 04-04-2009, 01:12 PM
T0Y0TuN's Avatar
Dealer : Westminster Toyota Ltd.
2008 Toyota Tundra,
2007 Lexus ES350,
2009 Toyota Camry HV Blue Ribbon w/Nav
Last Online: 05-02-2009 06:25 PM
Images: 3
T0Y0TuN is on a distinguished road.
T0Y0TuN's Photo Albums
Does anyone have any pictures? I am looking to install a HID kit on my 09 TCH. Any recommendations as far as brand/bulb color? I don't want the cheap blue or purple look.
Thanks-
Canada TCH Navigation studio69 Camry Hybrid 19 09-15-2007 12:01 PM
HIDs installed, now fog lights don't work yvranx42 1Gen-Tundra 14 08-22-2007 12:54 PM
Has anyone had a Sunroof/Moonroof installed on an 07 Tundra? tundrachick07 Tundra 6 06-06-2007 01:32 PM
HID's Installed PICS (56K Get Some Coffee) AFP520 1Gen-Tundra 21 10-24-2006 04:19 PM
ABS installed? maz Suspension & Axle 5 12-11-2003 07:28 PM
