Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry Hybrid
Old 02-10-2008, 12:49 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
2007 Toyota Camry HV
Last Online: 10-28-2009 02:33 PM
Jer is on a distinguished road.
Jer's Photo Albums
Default Oil change light: Based on miles or viscosity?
I'm relatively sure it's a simple odometer based warning but was curious if anyone knew for sure. I did an oil change 5k miles ago and the light is on again. I use synthetic oil so there's no reason to change it again at 5k miles so I plan to reset the check light and change it at the second one. Otherwise, I'm spending a LOT of money on longer lasting synthetic oil for nothing.
A right, not a privilege - ΜΟΛΩΝ ΛΑΒΕ
=-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
Old 02-10-2008, 03:30 PM
Dealer : Toyota of Naperville
2007 Toyota Camry HV 50th Anniversary,
2006 Toyota Corolla
Last Online: 09-02-2009 01:22 PM
9phil9 is on a distinguished road.
9phil9's Photo Albums
Default Re: Oil change light: Based on miles or viscosity?
The light comes on triggered by mileage only.
Old 02-10-2008, 05:25 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
Pretty much what I had assumed but where were you able to find this information? I wasn't able to find it to confirm my assumption.
Old 02-10-2008, 10:03 PM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 10-05-2009 12:31 AM
mral1515 is on a distinguished road.
mral1515's Photo Albums
Mileage and from working on numerous Toyota's
Master Toyota Tech
ASE Master Tech
Shop Foreman
16 years with Toyota
Old 02-11-2008, 12:14 AM
2006 Toyota Corolla
Feel free to ask anyone down at your local dealership.
Even the janitor will tell you that you are resetting the mileage in order to get the "Service Needed" light to go away.
If your system was based on usable oil life, there would be an indicator showing you the percentage left.
Toyota doesn't bother to print anything that obvious in your owners manual.
So it's a good thing you belong to this site and can get such important, and interesting information in print.
Old 02-11-2008, 12:36 AM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
Thanks fellas. I was pretty sure that was the case but wanted someone to back it up for me. Resetting and forgetting for the next 5k miles.
Old 03-03-2008, 04:42 PM
Marty358's Avatar
Dealer : Fiore Toyota
2005 Toyota Tundra,
- Other - '93 Toyota Celica GT
Last Online: 11-13-2009 10:41 PM
Marty358 is on a distinguished road.
Marty358's Photo Albums
If you reset and forget for another 5000 miles, the Toyota dealer may tell you to forget about your engine warranty. Check your owner's manual for oil change intervals. If you exceed, kiss your warranty goodbye even with synthetic oil.
Old 03-03-2008, 05:26 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
They would have to prove that any damage incurred is a direct result to user neglect and the viscosity of the engine oil would be tested first. Given standard use and synthetic oil there really is no reason your viscosity wouldn't be WELL within tolerances. I wouldn't have bothered asking this question unless I knew running 10k miles on my oil was safe. There's plenty of opinions but if you doubt mine, have your oil tested at 5k miles and 10k miles on full synthetic (naturally aspirated of course.. I wouldn't exceed 3k miles on a turbo charged vehicle) and you'll see that the numbers are just fine. If you pay for synthetic oil and change every 5k you're just wasting your money.
Old 03-03-2008, 10:37 PM
Marty358's Avatar
2005 Toyota Tundra,
My point exactly with the 5000 miles and synthetic, but make a claim and show 10,000 mile oil change intervals and you not the dealer will be paying for an engine. If you don't believe me , ask your dealer. I am only trying to help you avoid paying for an engine if you are within warranty. They always ask for maintenance records when you make a claim.
Old 03-04-2008, 12:25 AM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
*sighs*
I worked at dealerships before. I know how it works. Thanks for the concern.
Old 03-08-2008, 10:06 PM
Marty358's Avatar
2005 Toyota Tundra,
Since you have worked at a dealership, you know they will void your warranty because of the sludging problems and exceeding the 5000 mile limit. Why do you think they put that light there in the first place?
Old 03-08-2008, 10:25 PM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
Exclamation Re: Oil change light: Based on miles or viscosity?
i've seen plenty of engines with sludge and they all have one thing
in common. lack of oil changes.
i've seen plenty of engines without sludge and they all have one thing
in common. a lot of oil changes.
i use syn in my tundra and i've got 12,000 miles on it and i've changed the
oil five times.
since you would probably never put used oil in your engine, if you changed
it today, when would you conceder the oil used?
ever heard of someone damaging their engine from changing the oil too much?
the reason for changing oil is to get the crap that gets into the oil out of
the engine.
sludge is a technical term for "build up of crap."
i always like the commercials for syn oil that says "the engineers that designed your engine don't know what the fudge they are doing."
why change it at all? why not wait till 10,500 miles? save the money.
who pays $30,000 for a vehicle and then not change the oil?
yspert
Graduated from Y to Z status.
Old 03-08-2008, 10:32 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
Listen champ, I'm not getting into a pissing match with someone on the internet who clearly doesn't know the first thing about what they speak of.
For starters, the dealership does NOT void warranties. They don't even authorize them for that matter. A rep for the manufacturer authorizes and denies them. Now, for a manufacturer to void a warranty (and get negative publicity) they better have a damn good reason to do so. If you neglected your car and the oil got bad enough that they can prove it directly caused some sort of a malfunction then they can (and should) void your warranty based on these findings. This sort of thing is VERY rare contrary to internet gossip however. You're about 15x more likely to find a manufacturer honor a warranty claim that was the cause of owner neglect then you are to find them to deny a claim because of this. It's just good business.
If your oil is sludge then it should have been changed anyway. I'm talking about not changing perfectly good oil here and not trying to run sludge through my engine for an extended period of time. Again, run your car on conventional oil to 5k miles and then for 10k miles on synthetic and then send them both off to be analyzed. Until then you're just talking about something you have no idea of obviously.
Why would you come back to a thread that had been dead for 5 days to throw in your two cents other than to start some sort of petty argument?
Old 03-08-2008, 10:41 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
oil five times.
the engine.
sludge is a technical term for "build up of crap".
No, sludge is a term used to describe the oil when it's viscosity breaks down after thousands of heat cycles. Synthetic has the ability to heat cycle roughly twice as many times as conventional oil and therefore can be ran longer than conventional motor oil. If you have 'crap' building up in your engine then you need a better oil filter because it's job is to filter out all the contaminates that are suspended within the oil. The oils job is to lubricate all of the parts of the motor that are metal on metal. Over time and after many many heat cycles the oil will start losing it's ability to lubricate these parts and friction begins to occur. The result is added heat which also speeds up the process of the oil turning to sludge.
Bottom line is if you're oil is still good then it's still good. Sure you can change your oil weekly if you like but you would be stupid and throwing money out the window. I have managed to get hundreds of thousands of miles out of numerous vehicles doing it my way and have yet to have an engine fail because I didn't change the oil often enough.
Old 03-08-2008, 11:01 PM
yspert's Avatar
since i'm stupid, then i guess i just don't understand why one should
change their oil at all. why not just change the filter? yspert
