Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry Hybrid
  #16 (permalink)
Old 02-18-2009, 09:48 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: Did anyone run out of gas yet!
Originally Posted by ag4ever View Post
And if I do burn up a fuel pump, they are not that hard to replace.
Be thankful you dont have a PRIUS, You cant replace just the fuel pump, it's part of the fuel tank and not sold seperatly.
The HV Camry fuel pump is $350 APPROX at TS member price, and your right its not that hard to replace at all.
25 yrs with TOYOTA
  #17 (permalink)
Old 03-16-2009, 11:05 PM
Last Online: 09-25-2009 11:22 PM
motech is on a distinguished road.
motech's Photo Albums
If you do run out of gas it will not hurt anything a toyota only turns on the fuel pump when crankshaft rotation is recognized by the ecm if you want to test this remove your cuircut opening relay this will kill the fuel pump power you will probobly get a code for engine faild to start. The car will run on battery for less than a 5 minutes when the battery state of charge reaches 40% it will shut down and will not move until the key is cycled of and back on if this was an actual run out of gas situation it would do the same thing this will not burn out a fuel pump will not ruin anything just add gas and clear the codes even though your battery moniter on the dash says it is low the lowest it can get is 40% state of charge befor it shuts down
  #18 (permalink)
Old 10-30-2009, 02:26 AM
Last Online: 10-30-2009 02:28 AM
ann1985 is on a distinguished road.
ann1985's Photo Albums
Very good info here.
Thanks to all.
