I have been reading some owners are bumping the pressure to 40 psi in an effort to get better mpg. Ok, what's the downside?
Less tire "footprint" in contact with the pavement resulting in longer stopping distances, more wear in center of the tread. Rougher ride and more wear and tear on front end components.
.J
I figure the Toyota and Michelin folks know much more about their products and usage than I do. I prefer to go with their numbers and not worry about squeezing a little more mileage out. At 7,000 miles the car is at 43mpg with the stock settings.
I have a better idea, I hear others are using no air at all, just fart juice. It's free like air. But if yu fart till till it reaches 120 psi yu will get 79MPG.
And If yu don't have any, I will send it free, just pay shipping is all I ask.
Since yu are a member I will not charge yu a handling fee!
Toyota doesn't want yu to know about these anal tricks. They want yu to use the sticker in the door jamb for the PSI recommendation. How dare they put such stickers there with obvious "wrong" info!
I run the 40 psi on recommendation from an mechanical engineer (he works for Micheline) . The difference between what is recommended is only 4 psi yet the tire drag reduction is around 15%. I have not notice any change in the ride.
Bob
2009 Tacoma PreRunner Crew Cab. Wife's Car
2009 Camry Hybrid, Mine :
2008 Harley Davidson Screaming Eagle Road King-My Bike
2005 Harley Davidson Deluxe-Wife's Bike
1998 Honda Accord EX (Daughters, but I bought it)
2009 Corolla LE (Other daughter but she's paying for most of it)
Bob
I cranked mine up to 40psi for a weekend trip. I can now run over a dime and tell if it's heads or tails.
Bob
I work for Michelin as a Technical Design Consultant in R & D and your 15% figure is incorrect. Study basic calculus...it will help yu arrive at a more accurate figure.
The statement is "reduces tire drag". The tire drag coefficient is reduced by 15% and the math works. Tire pressure is increased by 12%, re-check your figures.
Got a life!!
Bob
Got a life!!
Bob
"TPC"...does this acronym ring a bell?
"Tire Performance Criteria" (Toyotas spec for the tire on your vehicle)
YU are exceeding your tires limits for a neglible net gain that is insignicant.
And, at the sacrifice of saftey, performance, and tire wear.
Force & Moment
Residual Aligning Torque (RAT)
Rolling Resistance
Braking Traction
Driving Traction
Uniformity
Noise
Dimensions
Mass
Rev/KM
High Speed
Air Retention
Electrical Resistance
Automatic Mounting
Endurance (ATE)
Treadwear
Chip/tear
Groove Wander
Ride & Handling
Wet/Snow Handling
Consider the above criteria as spec'd by Toyota.
Your theory impacts the above criteria, yu are exceeding the limits of the tire design. Altering the load range spec. too much.
Plain and simple... If yu advocate your PSI to others, make sure yu explain that it can be hazardous and not safe for some vehicles...
I know much about Tires. I don't brag much about anything. But Tires IS my passion. I will brag about my knowledge of them if need be just to prove my point. When we can both communicate in tire talk then we can debate further, using the same language.
I'm not into simple Rants. Or, Tit For Tat either.
Now analyze this and the Life yu say YOU have.
LT
Reason: sp
However, I have Micheline's Energy and stamped on the tires it states "max pressure is 44 lbs". Apparently one of the worlds largest tire manufactures saw fit to decrease tire drag for better fuel efficiencies. Therefore I am not exceeding the design limits of the tire. Think I will add 4 more lbs and see if I notice a difference.
It's a well know fact a high percentage of cars on the road are running on lower tire pressure than what is recommended. This, as you know, causes lots of it own problems.
What tires are on you car?
Bob
A tire dealer on another forum reported that he has seen tire failures caused by extreme overinflation. Theory is that the rubber and fabric plies stretch causing small separations at edge of steel belt -- and resulting in eventual loss of tread. No scientific proof but worth thinking about.
I'm typing this just to see how "quick reply" works. NOT to say that the people I've met who know the most about what they're talking about don't need to say so. ;-)
