Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry Hybrid
Old 10-31-2006, 07:02 PM
Dealer : Toyota of Kirkland
2007 Toyota Camry HV
Last Online: 12-04-2006 07:20 PM
Geckoboy is on a distinguished road.
Geckoboy's Photo Albums
Default How/where do I tap into +12V power source?
Hi All,
I got an aftermarket HID conversion kit. It looks like I'll need to tap into a 12v source. Since the battery is located in the rear of the vehicle, I am unable to connect the relay that comes in the kit to the battery.
Looking around, I'm not sure where/how else to connect it. I was thinking of getting a solderless wiring kit and splicing the headlight connector to connect the positive battery feed to the relay.
Does anyone have any suggestions? I'd rather not cut into the headlight wiring if possible.
Old 11-01-2006, 12:39 AM
Dealer : Wilder Toyota
Last Online: 01-17-2007 11:52 PM
herbQ is on a distinguished road.
herbQ's Photo Albums
Default Re: How/where do I tap into +12V power source?
In your car is a center armrest between the front seats. Ahead of that is a small plastic receptical. In that place you will find a little hole labeled 12v/120w. This may be what you are looking for. There may be a similar place for service from the rear seat, seems the Owner's Manual may have mentioned it, have a look. We used to have a saying in the flying business, "When all else fails, read the op manual".
Old 11-01-2006, 12:44 AM
Sorry, I did not understand your msg until reading it a second time. You are interested in re-doing your headlights somehow. I would ask for professional help in so doing. A new wiring harness for this technology car will probably run $1200-1500. It would be easy to fry the existing harness unless you understand the system.
Old 11-01-2006, 02:22 PM
Dealer : Sterling Mccall Toyota of Fort Bend
Last Online: 09-07-2007 01:30 PM
LThompson is on a distinguished road.
LThompson's Photo Albums
I've asked the tech folks at ZenonDepot.com this exact question. Will post when I get a reply.
At this point I know that while during regular time on, an HID uses about 35w power vs the 55w bulb in the stock halogen setup there is more to it. The HID system needs a big "kick" to get the gas in the HID bulb glowing and that is the function of the "ignitor" component. The question is how much much capacity in watts or amps does that need to safely be? It's tempting to just power the whole setup from the stock low beam connector but is it right/safe?
Old 11-01-2006, 06:46 PM
Elmo over at greenhybrid.com did it and he said it works. I've asked him what he did and I'm waiting for a reply.
After reading up on Automotive Lighting FAQ - headlamps and HID harness , I want to connect the xenondepot kit I just got directly to the battery, instead of splicing into the stock headlight connector.
I took a quick look around the engine compartment and could not immediately identify a spot to tap into a 12v source. I'm planning on running a wire somehow from the battery in the back to the front. My only problem is how to conceal the wire. I think they go through the driver side under the scuff plate, but I dont know. I'm not that well versed in auto servicing.
Old 11-01-2006, 10:02 PM
OK.... Steve at ZenonDepot emailed me back and said they do NOT recommend pulling the bulb power from the stock plug. Instead use the stock connector to close a relay that pulls power through a new wire from the battery or from somewhere in the engine bay. He said it needs to be able to handle the 17A draw when the HID ballast loads. Stock connectors provide about 9A (55w x 2 / 12v = 9A) so they are overloaded using them for primary power to HIDs. I'm looking at pulling a wire (16G) from battery through the car to engine bay. There is lots of info on getting 12v power for audio systems on the web.... it's just that they are backwards from us - battery source is in engine bay and their amps are in trunk!
Old 11-02-2006, 01:42 AM
Thanks for the info. The more I researched it, the more I decided against tapping the power from the stock headlight connector. I downloaded a copy of the camry hybrid service manual to see how I can pull a wire (18gauge) all the way to the battery. I'm new to reading the service manuals, but it looks like perhaps I can run a wire beneath the scuff plate either on the drivers or passenger side.
I guess I'll be disassembling my TCH over the weekend. Let me know what you end up doing in case you find an easier way to run a wire to the battery
Old 09-27-2007, 02:05 PM
Dealer : Toyota Scion of Hollywood
2008 Toyota Camry HV
Last Online: 09-27-2007 05:39 PM
mina323 is on a distinguished road.
mina323's Photo Albums
Can I ask where did you download the manual from??
Old 09-29-2007, 12:25 PM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Another Aftermarket HID mess in the brewing process....
"the blind leading the blind"
LT
New power outlet mod + engine noise question chrism Electrical & Computer Systems 8 02-21-2009 11:17 PM
Group dyno run results v8Toilet Off-Topic 82 10-23-2005 11:44 PM
Need switched 12V power source jfranciskay Electrical & Computer Systems 3 05-14-2002 05:29 PM
Head Unit Power nhparrot Audio & Stereo 0 03-28-2002 02:01 PM
Power sliding back window nhparrot Electrical & Computer Systems 0 03-28-2002 01:17 PM
