Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry Hybrid
Old 01-04-2007, 10:00 PM
Dealer : Rice Toyota
2005 Toyota Avalon,
2007 Toyota Camry HV
Last Online: 04-09-2007 06:49 PM
impulsives is on a distinguished road.
impulsives's Photo Albums
Angry Center console squeak!!
Does anyone else have a problem with the center console (around the shifter) squeeking? I have taken it to two Toyota dealers a total of 4 times and they still can't get it to stop. I assume they used foam damping material. I feel like I'm driving a Ford. I have 27000 miles, but it started at about 2000. Any suggestions?
Also, trying to be number 1 has hurt Toyotas overall panel fit on the interier, especially on the speaker covers and dash. This car was supposed to be made at the top Japanese plant, but I think my 2006 Tacoma was built much better.
Old 01-05-2007, 07:53 PM
Dealer : Priority Toyota
2005 Toyota Tundra,
Last Online: 11-15-2009 09:53 PM
dunebuggy73 is on a distinguished road.
dunebuggy73's Photo Albums
Default Re: Center console squeek!!
My wife's hybrid has had the same problem since about 1000 miles. I happen to work for our dealership as a mechanic but for a different manufacturer. I dropped my wifes Camry off to have a new key programmed and told the service advisor about the problem and were the noise was coming from. I also specificly showed him how to quiet it and told him I thought it needed foam tape to isolate the trim panels from one another. I picked up her car and it was quiet for a day. The advisor had told me that the tech had applied foam tape. Last weekend I was installing my wife's XM radio so I had to remove all the center console trim. Guess what?? No foam tape or any evidence the tech had attempted to stop the squeak. Now I am not surprised it still squeaks. When I get an opportunity I am gonna put some foam tape in between the panels. Just so you know the trim around the shift knob pops out. I am fairly sure the noise is coming from were that peice is touching the surrounding plastic trim. All those plastic trim peices basicly pop out. Just take care. Best advise is to explain it to a trustworthy dealer and let them know were the noise is. As a technician for a high line manufacturer I was a little disappointed but things happen and we all have bad days.
Old 01-10-2007, 04:43 PM
TundraSoul's Avatar
Account Manager
Dealer : Bingham Toyota Scion
2007 Toyota Tundra 4x2 Sport Truck,
2010 Toyota Prius V,
- Other - 2006 Kia Sedona
Last Online: Today 03:21 AM
Images: 89
TundraSoul has blessed us with their presence. TundraSoul has blessed us with their presence. TundraSoul has blessed us with their presence.
TundraSoul's Photo Albums My eBay
Yes, we have the same problem. If you move the shifter left to right (jiggle it) while your moving, the squeak is louder.
Website Founder
I drive a 2007 Toyota Tundra 4x2 Sport Truck, 5.7L V8. DZ BU EC EM FE HM PN RN SL SM SP WR Black over Gray / Black interior.New pics and details coming. Follow me on Twitter.
Old 01-10-2007, 06:41 PM
2005 Toyota Avalon,
Default Re: Center console squeak!!
Thanks,
I will be taking mine back in for a 4th time this week. They have a foam kit that along with the foam tape should fix the problem. I don't think they even check it out after they do what they do. I drive alot and this high squeak is driving me up the wall!
Old 02-01-2007, 12:15 PM
Guest
Dealer : Bayside Toyota
2004 Toyota Tundra,
Last Online: 02-16-2008 06:47 PM
longtrav is on a distinguished road.
longtrav's Photo Albums
Angry Re: Center console squeak!!
same problem, if you push down on the plastic in front of shifter it stops! I want this fixed hopefully there will be a recall or service bulletin
Old 02-02-2007, 09:31 PM
2005 Toyota Avalon,
I finally had them replace my center console below the shifter and it fixed the problem.
Old 02-03-2007, 09:57 AM
Guest
2004 Toyota Tundra,
do you have any info on the repair that I could tell my dealer? thanks for the update. I did notice IF I push down in front of the shifter and apply pressure it stops.
Old 02-12-2007, 09:15 PM
Dealer : Abajian Toyota
2006 Toyota Tundra,
2006 Toyota 4Runner Limited Salsa Red
Last Online: 04-11-2007 09:18 AM
toyotatim is on a distinguished road.
toyotatim's Photo Albums
the problem is between the shifter trim upper plate and the plastic pieces bonded to the bottom of the plate. This is ONE assembly and will require replacement, foam tape will not work. Modification may be the answer until a corrected part is available.
Toyota Dealership Employee
Old 04-22-2007, 01:48 PM
Dealer : Chomedey Toyota
Last Online: 03-20-2009 09:58 PM
gillesmtl is on a distinguished road.
gillesmtl's Photo Albums
I fixed the problem in mine last year, and the solution lasts.
Around the shifter there is a clear plastic part that surrounds the shifter. That part comes with the main color-coordinated console cover when you pry it up. That clear plastic is aluminized in some areas. It is its bottom face that squeaks against the fixed part of the console. Stick a layer of electrical tape along the shifter opening, taking care not to obscure the area used for lighting the shifter position lettering.
That's it. You won't hear it again, from -20° to +80°.
Good luck.
06 Tundra Sat Mount (Center Console) wilkergobucks Audio & Stereo 18 03-27-2007 11:49 PM
06 Tundra Sat Mount (Center Console) wilkergobucks Tacoma 1 01-05-2006 02:58 PM
HOW TO: Install a '03 Tundra, Center Console in an '01 atomic80 Member Mods 1 12-18-2005 12:34 PM
2005 Tacoma In-Cab power Outlet sbessel Member Mods 0 03-22-2005 10:00 PM
03' Tundra Center Console Installed In An 02' ZIGGY454 Interior & Exterior 7 01-02-2004 11:00 PM
