Originally Posted by steve1214
Need help finding the location for the drivers side door lock actuator for a 2004 solara se sport. If its in the door i need help removing the door panel.
Thanks
Here is a PDF on OVERHAULING the door.
YOU DONT NEED TO DO ALL THE STEPS to remove the door lock/actuator assy.
You will need a torx "T30" male socket to remove the outer door handle to gain access to the lock/latch assy.
Its alot of work
GOOD LUCK
25 yrs with TOYOTA
