Go Back   Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
Unichip.com
Old 12-16-2007, 09:24 AM
Dealer : Michael Toyota
2007 Toyota Corolla,
2006 Toyota Camry-Solara Convertable
Last Online: 09-23-2008 04:40 PM
circpro is on a distinguished road.
circpro's Photo Albums
Default Why are Toyota Batteries so Bad
My wife's o6 Solara battery dead after 22 months. My 07 Corolla battery went bad after 6 months. I live in CA so cold weather is not an issue. Anybody else have these issues?
Old 12-18-2007, 03:09 AM
PXLpainter's Avatar
Moderator
Dealer : Carson Toyota Scion
2006 Toyota Camry-Solara V6 SLE Convertible
Last Online: 07-02-2009 10:36 AM
PXLpainter is on a distinguished road.
PXLpainter's Photo Albums
Default Re: Why are Toyota Batteries so Bad
IMO, ALL OEM batteries are useless after about 15 months - has been that way since I've been buying new cars since the late 70's and living in several states in all weather conditions. I always either get a new one under warranty or just get a Die Hard or Optima and move on.
Old 12-18-2007, 04:41 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 11:03 AM
kathyricks's Photo Albums
The OEM batteries in the four Toyotas I purchased brand new all lasted between 6 - 9 years. Owners that are getting only months of life from their batteries must be doing something that murders them.
Old 12-19-2007, 01:03 PM
PXLpainter's Avatar
Moderator
Yeah... it's called starting the car and driving. Consider yourself very lucky... or perhaps you don't drive your cars that much/often.
Old 12-19-2007, 05:40 PM
kathyricks's Avatar
1993 Toyota Truck
Just the opposite. The Toyotas I own which I DON'T drive often have sufferered early battery failure because they drain down due to parasitic drain from acessories like the electric clock.
But the Toyotas I drive daily have consistently had long lived batteries, presumably because they always stay fully charged. Also, I check the water level occassionally to make sure no cells ever run low.
Old 12-19-2007, 06:36 PM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 06-22-2009 09:36 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
For the most part, Hot climate degrades batteries faster than colder climates. Non use is bad as kathyricks states. i.e. parasitic current draw.
Batteries are installed/sold with climate specific characteristics based on the region yu purchase the battery. So if yu buy a Southeastern States Toyota distributed vehicle. it doesn't have the "cold pack" specs. In the Northeast and Canada, yu get the "cold pack" spec'ed car with cold climate batt. This has been battery industry practice for 40+ years.
If yu buy a battery in a Sears in FL,yu will get a hot climate rated battery.
In Minnesota yu get the cold spec battery.
I find in general that the Toyota OE batteries from the Factory are best. Most I've seen are the Japan Panasonics. I'l get more than 5 years of good service. Every Toyota I've ever owned had this battery. The most I've got was more than 7 years. And although they say maintenance free yu can remove the stickers off the cell caps and top-off with distilled water, usually around 4-5 years later and yu might squeeze another year or two out.
If yu abuse and deep cycle any battery yu will definity lose service time of that battery. Auto batterries are not designed to be deep cycled (go dead) and recharge. Marine batteries are only designed for this.
The Dealer replacement "Toyota True Start" batteries are simply overpriced Garbage. Budget stuff just rebranded "FOR" Toyota dealers.
They just will never last more than the OE Panasonics which just are unattainable anywhere here Domestically last I searched.
The dealer will not and cannot get yu this Exact Originally Installed battery.
LT
Old 12-19-2007, 06:44 PM
LifeTech's Avatar
BTW, the OE battery is only warranted for the 3 year /36mos .
Toyota only needs to warranty the battery for this time period.
And, it's just business and profit at it's best.
But most car companies are like this.
Everthing is calculated for it's "End Of Life" expectancy.
LT
Old 12-19-2007, 06:51 PM
LifeTech's Avatar
I like Interstate Batteries and have had great service with the premium models.
Diehard's use to be great in the 80's, but were changed over to a different mfr. and as of late are not the best batteries despite the great marketing of it's trade Name for some years.
There are only several Companies that actually make Domestically available Lead acid batteries. They are contracted and just rebranded.
LT
Old 12-19-2007, 06:53 PM
PXLpainter's Avatar
Moderator
Indeed - so I've learned that living in SoCal, the OEM batts "might" make it towarranty age, but not always. Depending on my needs (aux lights, audio, accessories, etc.) I may replace with a Duracell or Optima regardless, but as in the case of my last Camry, we got two new batts under the 36 mo warranty period due to defects - nothing wrong with electrical system, as the last batt then went on to last 3 more years with no probs.
I think it may also just be a case of where the battery comes from through the factory or dealership - since all the Toyota models are built in different parts of the globe - one can assume so do the consumable parts they put into them.
Old 12-20-2007, 02:30 AM
kathyricks's Avatar
1993 Toyota Truck
One OE battery I had that lasted up to 9 years was a Delco battery! And I drove that vehicle daily up and down California's furnace like Central Valley in the summertime. So I disagree with the suggestion that hot climates kill batteries.
I've found that batteries that suffer frequent partial discharge via parasitic drain due to not driving for 2 weeks or more don't live more than about 2 years. For that reason, I buy the Walmart batteries that come with a 3 year free replacement guarantee for the cars I don't drive regularly. And I've used that guarantee to my advantage several times.
Country where a Toyota is built is not a reliable indicator of the brand of battery or other parts it may carry. Example: My 1992 Toyota pickup was built in Fremont, Calif. yet it came equipped with a Panasonic battery and Tokico (Japanese) shock absorbers. And my '93 Toyota pickup was built in Japan yet came with a Delco battery and Monroe shock absorbers.
Old 06-09-2008, 12:38 PM
Dealer : Miller Toyota
2003 Toyota Tundra
Last Online: 03-12-2009 12:12 PM
maxtorqe is on a distinguished road.
maxtorqe's Photo Albums
As of today my OEM battery in my 2003 Tundra has lasted 5 1/2 years. It just died on my son this morning. I could tell it was getting weak this past winter as it was cranking slower on the colder mornings (not so cold in northern VA this past winter). Then I noticed that it was starting to crank slower again lately as it has gotten warmer. I think the high heat these last few days (98F) finally did it in. Other Tundra owners here at my office (there are several) all have their original OEM batteries or have just recently replaced them after 5 or more years of service. The longest was 7 years.
Of the GM cars I have had, I've never had the AC Delco batteries last more than 4 years.
My typical replacement preference has been Interstate, but this time I told my son to stop by the dealership and pickup another "Toyota" battery, the cost is about the same. BTW the current OEM in my truck is made by Exide (stamped on the top label), who also makes the Optima batteries. (see link: Optima And Exide Revolutionize The Car Battery - Popular Mechanics)
Maxtorqe
2003 Tundra Access Cab SR5 V8 4X4
No real mods except for:
Bosch Platinum +4 plugs
BF Goodrich Long Trail T/A Tour - 265/70 R17s
Bilstein HD shocks (non TRD)
Hellwig Anti-Sway Bar
Old 08-02-2008, 10:32 AM
Dealer : Toyota of Augusta
2003 Toyota Tundra
Last Online: 08-02-2008 10:34 AM
chief206 is on a distinguished road.
chief206's Photo Albums
This is not a reply but a question. My 03 Tundra 's battery is dead if I don't start it every 2 days, is this normal in tundras. Does the access. Thanks chief206
Old 08-02-2008, 12:10 PM
PXLpainter's Avatar
Moderator
^^ Not normal.
You might check in the Tundras forums for threads relating to their batteries as well.
Old 12-18-2008, 03:38 PM
Dealer : DCH Freehold Toyota Scion
2006 Toyota Camry-Solara convertable,
2000 Toyota Tundra single cab-V-6 8ft b
Last Online: 06-27-2009 08:50 AM
coal miner is on a distinguished road.
coal miner's Photo Albums
What about these jell batteries? Are they any better than the lead acid batteries? Some comments please. Thanks Coal miner
Old 12-20-2008, 05:31 PM
Last Online: 12-20-2008 10:12 PM
Steved0603 is on a distinguished road.
Steved0603's Photo Albums
Thumbs up Re: Why are Toyota Batteries so Bad
The not driving very often scenerio with dead batteries makes sense to me and is something I need to think about with my next purchase. I bought a motorcycle this summer to combat high gas prices and sometimes went 2 weeks without driving my 4Runner (still riding it in the winter, too.). Battery just died this weekend. Of course, it was 6 years old and was the Panasonic version, so it was about time for it to go anyway. Bought it from a local Toyota dealer back in late 2002. That was the second one I've had. The first was the original in my '97 and it lasted about 5 years.
Glad I found these posts, because I was going to go buy a Toyota True Start on Monday. May as well buy a cheaper one at Autozone or somewhere since it's probably gonna die early anyway with my new driving habits.
