Re: 2000 Solara
REMOVE CYLINDER HEAD COVER
Remove the 4 nuts, grommets, head cover and gasket.
HINT:
Arrange the grommets in the correct order, so that they can be
reinstalled into their original positions. This minimizes any possibility
of oil leakage due to reuse of the grommets in different
positions.
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
