Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
Old 04-28-2009, 12:53 PM
2005 Toyota Camry,
2000 Toyota Camry-Solara
Last Online: 05-11-2009 09:19 PM
JetDriver is on a distinguished road.
JetDriver's Photo Albums
Default Charcoal cannister replacement
Hi All,
I have a 2000 Solara that is in need of a new charcoal canister according to the dealership. I had CEL codes of P0440 and P0446. The price for repair was quoted at $425. I was told they have to drop the fuel tank for this repair. Is the price accurate for the replacement of a charcoal cannister and is this something I could do myself?
Thanks,
Brian
Old 05-15-2009, 10:30 AM
Dealer : DCH Freehold Toyota Scion
2006 Toyota Camry-Solara convertable,
2000 Toyota Tundra single cab-V-6 8ft b
Last Online: 11-13-2009 09:24 AM
coal miner is on a distinguished road.
coal miner's Photo Albums
Default Reply to charcoal canister?
I could be wrong but I always thought the charcoal canister was under the hood somewhere? Its function is to prevent fuel tank vapors from escaping into the air. Are you sure they are not talking about something else etc. Speaking of filters have you checker your cabin air filter? Its right behind the glove box - as easy as pie to replace. coal miner.
Old 05-18-2009, 03:45 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: Charcoal cannister replacement
The canister on a solara is in the rear above the rear crossmember, you DO NOT have to remove the gas tank to replace it, but you have to lower the rear crossmember and the muffler.
With p0440 and p0446 I would start with the CCV valve as described in the TSB I have attached, then maybe the canister or ORVR, that would depend on a smoke test and /or evap pressure test.
I would need your VIN to see if this TSB applies to your vehicle.
25 yrs with TOYOTA
