Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
Old 01-02-2006, 12:55 PM
Dealer : Toyota of Muscatine
2005 Toyota Tundra
Last Online: 06-24-2009 05:17 PM
DSWhite is on a distinguished road.
DSWhite's Photo Albums
Default 6 Disc CD Problems-HELP
I have a 2000 Solara and loaded the CD player with six Disc's . I then got an error 3. Now knowthing will play or work. Is there a way to reset this? What does the error mean?
Dave
Old 01-03-2006, 12:04 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: 6 Disc CD Problems-HELP
Dave
Look thru your owners manual page 113
If “WAIT” appears on the display,
it indicates
that the inside of the player unit
may be too hot due to the very high ambient
temperature. Remove the disc or magazine
from the player and allow the player
to cool down.
If “Err 1” appears on the display,
it
indicates the disc is dirty, damaged, or it
was inserted up–side down. Clean the
disc or insert it correctly.
If “Err 2” appears on the display,
it
indicates no disc is loaded inside the
magazine. Insert a disc.
If “Err 3” or “Err 4” appears on the
display,
it indicates there is a trouble inside
the system. Eject the disc or magazine.
Set the disc or magazine again.
If “OPEn” appears on the display,
it
indicates the compact disc auto changer
lid is open. Close the compact disc auto
changer lid.
If the malfunction is not rectified,
take
your vehicle to your Toyota dealer.
DISC
By using this button, you can select a
disc you wish to listen to.
Push either side of the button until the
number of the disc you want to listen to
You can try disconnecting the battery for 5 minutes and see if this resets the system. If it does not then the radio needs to be repaired.There is a internal malfunction.
25 yrs with TOYOTA
Old 12-11-2007, 02:24 AM
Dealer : Ross Toyota
2007 Toyota 4Runner
Last Online: 12-11-2007 07:19 AM
tesfaye tilhaun is on a distinguished road.
tesfaye tilhaun's Photo Albums
Hi memebers this is my first posting I have toyota 74841 cd player
with six disc's Now knowting will play or work it desplayed error 3
What is error3 how can solved this proplme
Old 12-11-2007, 07:14 AM
2007 Toyota 4Runner
pleace display amanual pag 113 or how to got manual
Old 12-11-2007, 07:18 AM
2007 Toyota 4Runner
pleace display a manual pag 113 abut error 3
Old 12-12-2007, 08:02 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Your 4 runner is on page 206 of the owners manual.
Error messages
If the player malfunctions, your audio system
will display following error messages.
“WAIT”:
The compact disc player unit
may be too hot. Allow the player to cool
down.
“ERROR 1”:
The disc may be dirty, damaged
or inserted incorrectly (up−side
down). Clean the disc and re−insert it.
“NO DISC”:
The compact disc changer of
the separate unit is empty. Insert a disc.
“ERROR 3”:
There is a problem inside
“ERROR 4”:
Over−current. Ask your
Toyota dealer to inspect.
“CD OPEN”:
lid of the separate unit is open. Close the
compact disc changer lid.
Unplugging the radio SOMETIMES resets it, but it is usually an internal audio problem.
25 yrs with TOYOTA
LinkBack to this Thread: http://www.tundrasolutions.com/forums/camry-solara/54954-6-disc-cd-problems-help/
Posted By For Type Date
CD Player Error - TTORA Forum This thread Refback 07-05-2009 07:46 PM
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
Tundra rear main seal Vu Engine & Drivetrain 26 04-03-2008 11:35 AM
Single disc JBL to 6 disc JBL upgrade problems ScottTRD Audio & Stereo 13 04-02-2008 01:06 AM
Bugs, TSB's, problems worked out on 06' Tacos??? paulphilly Tacoma 11 10-18-2005 02:22 PM
Transmission problems and production dates. Joel K Engine & Drivetrain 1 01-05-2004 07:04 AM
