Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
  #16 (permalink)
Old 06-13-2006, 04:09 PM
Dealer : Toyotaland
1996 Toyota Avalon,
2008 Toyota Camry HV
Last Online: 11-11-2009 08:02 PM
haroldo is on a distinguished road.
haroldo's Photo Albums
Default Re: 96 Camry heat/fan control knobs lights
Geez...this looks a lot more hi tech than the other one!
Maybe I should just keep a flashlight in the glove compartment!
I don't mind fooling with something simple, but I'd sure hate to goof when it comes to this...unless you think this is easier than it looks!
  #17 (permalink)
Old 06-13-2006, 04:17 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
It is easy for me, Ive been doing it 20+ years.
Costco has batteries on sale all the time
Find a friend who may know just a tad bit more than you (automotive) and tackle it together, and if it doesnt work, you can blame him.
25 yrs with TOYOTA
  #18 (permalink)
Old 07-07-2006, 06:17 AM
Dealer : Toyotaland
1996 Toyota Avalon,
Originally Posted by mustang67408
AUTO it is. Good pic. THANKS
It is basically removing the same pieces as the camry.
Hey, thanks for all your help, I ended up bringing it to a body shop (other work was needed) and he popped in the new bulb in a few minutes. I would have ended up destroying the car if I had tried it!
One more thing, where can I get a replacement volume knob for the radio. Mine is a little broken. The inside connector that holds it on the metal pipe is cracked so it is loose. I taped the inside together so it stays on. The knob is visible in the image http://www.tundrasolutions.com/forum...knobs-66_3.jpg .
  #19 (permalink)
Old 01-05-2007, 08:31 PM
Dealer : North Hills Toyota
2004 Toyota Camry
Last Online: 01-17-2007 10:35 AM
jostrosky is on a distinguished road.
jostrosky's Photo Albums
I have a 2004 camry with the same problem; I didn't see the PDF here. Any thoughts on how to do it on a 2004? Temperature and fan speed lights...
Thanks
  #20 (permalink)
Old 01-09-2007, 01:27 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Thanks
The A/C controls POP out (see pic)
Then replace bulbs as necessary
25 yrs with TOYOTA
  #21 (permalink)
Old 01-17-2007, 08:38 AM
2004 Toyota Camry
umm. That picture is for the XLE I think; I only have an LE with just the knobs, not the climate control. I did try pulling on them "lightly" (a decent tug) - is it still just pulling them?
I'm afraid to pull too hard if they aren't supposed to come off, but I honestly can't imagine them engineering them some other way....but stranger things have happened.
  #22 (permalink)
Old 01-17-2007, 09:34 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
That is the only picture in the Toyota manual. The controls with the knobs (manual a/c) come out the same way. THE KNOBS DO NOT COME OFF. The whole assy as indicated in the picture comes out as a unit. You gain access to the bulbs from the back side.
25 yrs with TOYOTA
  #23 (permalink)
Old 01-17-2007, 10:35 AM
2004 Toyota Camry
Thanks very much!!!
  #24 (permalink)
Old 04-02-2007, 01:42 AM
Dealer : Toyota Walnut Creek
2003 Toyota Camry
Last Online: 04-08-2007 03:19 AM
tomgreen1000 is on a distinguished road.
tomgreen1000's Photo Albums
Default 2003 Camry heat/fan control knobs lights
Does anyone have a part number for the replacement lamp for the heater/fan control illumination for a 2003 Camry. It is a miniature incandescent with a flat base and wire leads. Thanks!
Tom
  #25 (permalink)
Old 04-04-2007, 11:14 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Default Re: 2003 Camry heat/fan control knobs lights
Tom
Manual or Auto A/C?
25 yrs with TOYOTA
  #26 (permalink)
Old 04-05-2007, 02:47 AM
2003 Toyota Camry
Manual. Thanks for your help.
Tom
  #27 (permalink)
Old 07-10-2007, 07:15 AM
Dealer : Toyota Cap-a-l'aigle
1997 Toyota Camry
Last Online: 07-14-2007 09:23 PM
oggie is on a distinguished road.
oggie's Photo Albums
Hi,
I'm new to this and not quite sure how this works. How do I get a copy of that pdf for removing the Camry dash?
Oggie
  #28 (permalink)
Old 11-25-2007, 05:18 PM
captainzerocool's Avatar
Dealer : Bill Penney Toyota
1995 Toyota Camry,
1993 Toyota Truck SR5
Last Online: 07-05-2009 02:40 PM
captainzerocool is on a distinguished road.
Send a message via ICQ to captainzerocool Send a message via AIM to captainzerocool Send a message via MSN to captainzerocool Send a message via Yahoo to captainzerocool Send a message via Skype™ to captainzerocool captainzerocool's Photo Albums
Originally Posted by oggie View Post
Hi,
Oggie
I too am looking for the PDF. It would be greatly appreciated.
Thanks.
  #29 (permalink)
Old 11-25-2007, 05:22 PM
Dealer : Toyotaland
1996 Toyota Avalon,
Originally Posted by captainzerocool View Post
I too am looking for the PDF. It would be greatly appreciated...
Not sure if this helps, but try this CamryManuals.com-Toyota factory service manuals - -
  #30 (permalink)
Old 11-25-2007, 05:42 PM
1995 Toyota Camry,
That is awesome. Thanks much.
