Go Back   Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
Old 02-18-2006, 04:29 PM
Dealer : Beaver Toyota Of Santa Fe
1996 Toyota Camry
Last Online: 02-19-2006 04:39 PM
dfaragalli is on a distinguished road.
dfaragalli's Photo Albums
Arrow 96 Camry heat/fan control knobs lights
Anyone know why all my dashboard lights work except the ones at the tips of the heat and fan knobs? I can't figure out where the fuse might be (if there is one) for just these knobs.
Old 02-18-2006, 11:30 PM
nhparrot's Avatar
Assistant Administrator
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: 10-10-2009 08:00 AM
nhparrot's Photo Albums
Default Re: 96 Camry heat/fan control knobs lights
Probably the bulb in the switch/knob. Believe all the dash lights are on the illumination circuit.
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 02-19-2006, 12:33 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence.
You are correct.
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
Old 06-13-2006, 01:58 PM
Dealer : Toyotaland
1996 Toyota Avalon,
2008 Toyota Camry HV
Last Online: 11-01-2009 08:04 PM
haroldo is on a distinguished road.
haroldo's Photo Albums
Hi there,
I am not comfortable 'messing around' under the dash board.
The heat knob (shows the line pointing to the temperature) and the surrounding temperature numbers fail to illuminate...most of the time.
For some reason, every now and then they illuminate (for a few minutes). Since dead bulbs and blown fuses (usually) don't come back to life and then die again only to come back again, I'm going to guess that the bulbs and fuses aren't blown (although I am not an expert).
The lights have illuminated two or three times in the last year.
Any clue on what could cause this behaviour?
Old 06-13-2006, 02:52 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Originally Posted by haroldo
Hi there,
First thing I would do is replace the bulbs. he vibrations will make them come to life now and then. (its also the cheapest thing to start).
The next thing I would check is the wiring to the bulbs while you in there replacing the bulbs.
24 yrs with TOYOTA
Old 06-13-2006, 02:57 PM
Dealer : Toyotaland
1996 Toyota Avalon,
I'm pretty good at changing bulbs in the den and living room, but never did it in the dashboard, is there an easy way to do it...for the novice. Any online explanations? Thanks!
Old 06-13-2006, 03:09 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Here is a pdf on how to take the dash out.
Only USE STEPS 1 -23
There are 2 bulbs for that heater knob control. (bulb # 90069-98004)
Hope this helps.
24 yrs with TOYOTA
Old 06-13-2006, 03:11 PM
Dealer : Toyotaland
1996 Toyota Avalon,
Wow!
Thanks...would I need any special tools?
Old 06-13-2006, 03:16 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
DO NOT REMOVE STEERING WHEEL (SKIP STEP 6) the dash will come out, just hold your tounge properly.
Some of the other steps may be unnecessary as well, use your judgement. If it says remove something on the passenger side and you see it does not interfere with the piece your after then skip that step. If in doubt then remove it, beats breaking things.
This is the only documentation I could find showing the heater control removal. It is really for the dash removal.
A phyllips screw driver, 8mm and/or 10mm socket and wratchet w/extension.
24 yrs with TOYOTA
Old 06-13-2006, 03:20 PM
Dealer : Toyotaland
1996 Toyota Avalon,
Hey, I'm a little intimidated by some of this stuff, and can see my car in a hundred pieces!
There are a lot of instructions there...which ones should I pay attention to, and which should I ignore, I mean #8 Remove Console Upper Panel, is one that I can probably ignore.
I appreciate your help, but before I destroy my car, I thought I would ask you to hold my hand, thanks!
Old 06-13-2006, 03:28 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
This should get you in the ball park.
7. REMOVE STEERING COLUMN COVERS
10. REMOVE COIN BOX
(a) Press on the sides of the box while pulling the box outward.
(b) Remove the box.
11. REMOVE INSTRUMENT PANEL LOWER PAD
(a) Remove the 2 screws and the coin box bazel.
(b) Remove the 4 bolts, screw and lower pad.
18. REMOVE CENTER CLUSTER FINISH PANEL
Using a screwdriver, remove the panel then disconnect the connectors.
HINT:
Tape the screwdriver tip before use.
19. REMOVE CLUSTER FINISH PANEL
HINT:
Tape a screwdriver tip before use.
(a) Remove the 4 screws.
23. REMOVE HEATER CONTROL
(a) Pull of the heater control knobs.
(b) Remove the 5 screws and hang the heater control.
(c) Disconnect the air mix damper control cable.
(d) Remove the heater control.
24 yrs with TOYOTA
Old 06-13-2006, 03:29 PM
Dealer : Toyotaland
1996 Toyota Avalon,
...and one more thing, I own a 96 Avalon...the PDF was for a Camry
I piggy-backed this thread because it was similar to my problem, before I realized that this is a Camry forum.
Old 06-13-2006, 03:36 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
DOH!!
Do you have auto a/c?
This is a whole nother ball game.
24 yrs with TOYOTA
Old 06-13-2006, 03:38 PM
Dealer : Toyotaland
1996 Toyota Avalon,
Sorry!
It is the Avalon with the thermostat twist knob.
96 Camry heat/fan control knobs lights-66_3.jpg
Old 06-13-2006, 03:49 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
AUTO it is. Good pic. THANKS
It is basically removing the same pieces as the camry.
24 yrs with TOYOTA
