Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
  #136 (permalink)
Old 02-16-2009, 01:01 PM
08SalsaMax's Avatar
Last Online: Yesterday 10:01 PM
Images: 43
08SalsaMax will become famous soon enough. 08SalsaMax will become famous soon enough.
08SalsaMax's Photo Albums
Default Re: Solara Questions - ASK ME!
Originally Posted by mustang67408 View Post
Your right, it sounds like just the light bulb for the cruise.
your going to have to remve the combiation meter. Turn it around, the bulb housing should twist out about 1/4 turn and the bulb pulls right out, if I remember correctly.
Mustang, went out there and got hit with a splash of cold water..... How do you remove the bezel with the clear plastic cover over the cluster? I was hoping that the four screws were right there as the pic shows, but it appears they are covered. THANKS !!!!
2008 Toyota Tundra 5.7L 4x4 Limited Salsa Red CrewMax
  #137 (permalink)
Old 02-16-2009, 03:34 PM
Dealer : Toyota of Killeen
2004 Toyota Tundra,
1999 Toyota Land Cruiser,
2008 Toyota Camry-Solara SLE Convertible
Last Online: Yesterday 01:39 PM
labountyphoto is on a distinguished road.
labountyphoto's Photo Albums
Does anyone know how to disable the seat belt chime an '08 Solara? I've searched and found a couple of suggestions but they didn't work.
  #138 (permalink)
Old 02-16-2009, 03:42 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
You need the TOYOTA SCAN tool to do this, it is a CUSTOMIZE PARAMETER.
CUSTOMIZE PARAMETERS
1. METER/GAUGE SYSTEM
NOTICE:
Be sure to record the current value before customizing.
The following items can be customized using Techstream.
METER:
Tester Display
Contents
Setting
Key Remind Volume
Large
Function to change the volume of the key remind warning buzzer
Large, Medium, Small
Key Remind Sound
Slow
Function to change the cycle of the key remind warning buzzer
Fast, Normal, Slow
Seat-belt Warning Buzzer (*)
D/P On
Function to change the setting of the seat belt warning buzzer.
D/P On, D On, P On, D/P Off
*1: This setting is only valid for the buzzer which sounds at the 20 km/h (12 mph) or more and the driver seat belt is unfastened.
25 yrs with TOYOTA
  #139 (permalink)
Old 02-16-2009, 03:48 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
If i remember correctly...(see pic)
remove 2 screws or plastic clips in the finish panel and then it should pop out, letting you access the 4 screws
25 yrs with TOYOTA
  #140 (permalink)
Old 02-16-2009, 05:13 PM
2004 Toyota Tundra,
NOTICE:
METER:
Tester Display
Contents
Setting
Key Remind Volume
Large
Key Remind Sound
Slow
Fast, Normal, Slow
D/P On
Thanks! Now to find a scan tool!
  #141 (permalink)
Old 02-16-2009, 05:15 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
I know there are many times we as a DEALER will do that for free for customers, some dealers do, some don't )FREE) they charge for it. We figure it is a simple tool to help keep people happy and really doesnt take to long. It's a win win for everyone.
25 yrs with TOYOTA
  #142 (permalink)
Old 02-16-2009, 05:29 PM
2004 Toyota Tundra,
Mybe they'll do mine free. Between my wife, daughter and I, we've bought 10 cars from them over the years.
  #143 (permalink)
Old 02-16-2009, 05:41 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Doesnt hurt to ask.
If they dont and your ever in LV, we will. LOL
Good Luck
25 yrs with TOYOTA
  #144 (permalink)
Old 02-20-2009, 05:38 PM
08SalsaMax's Avatar
Images: 43
Well, with your help, I was able to take the cluster off and check the light - it was fine. Looks like I have a loose connection to the light somewhere, just unsure how to chase it.
  #145 (permalink)
Old 02-20-2009, 05:55 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Well, the signal for that light to come on comes from the cruise control ECU. Then goes thru a junction connector in the middle of the harness and then thru CONNECTOR IF2
then to the combination meter. I added some pdf's for the location and display of the connectors and Cruise Ecu. Your going to have to trace it while it is doing it and see if your losing the ground or power. The power comes from pin 7 (red/light blue wire) of the combination meter connector C13. The ground is controlled thru a Transister in the Cruise ECU (orange wire).
25 yrs with TOYOTA
  #146 (permalink)
Old 02-20-2009, 06:53 PM
08SalsaMax's Avatar
Images: 43
WoW. THANKS !!!! That's a lot of tracing. Will let you know how I do.
  #147 (permalink)
Old 03-21-2009, 08:10 PM
Dealer : Elgin Toyota
2006 Toyota Camry-Solara Black SLE
Last Online: 07-12-2009 12:15 AM
RRMIKE is on a distinguished road.
RRMIKE's Photo Albums
Unhappy Re: Solara Questions - ASK ME!
HI;
I have a 2006 SLE all black I have two questions first is I take very good care of my car and I have never seen a worse paint job on any car I have ever owned. The paint is so thin there are so many chips on the hood and the sides of the front fenders from stones that are thrown up from other cars I will most likely never buy another Toyota just for that reason.Next does any one know if it is possible to change brake pads yous self or do I need to take it in.
Thanks RRMIKE
  #148 (permalink)
Old 03-23-2009, 02:02 AM
PXLpainter's Avatar
Moderator
Dealer : Manhattan Beach Toyota
2006 Toyota Camry-Solara V6 SLE Convertible
Last Online: 11-06-2009 11:51 AM
Images: 9
PXLpainter is on a distinguished road.
PXLpainter's Photo Albums
Yes, Toyota Paint is notoriously thin. I recall everyone bitching about it back when I first got my 2001 Tundra. Nothing has changed.
And yes, you can replace your own brake pads quite easily if you know how. Usually only take me about 30 minutes to do all 4 wheels with a hand jack in my garage.
PXLpainter
• 2001 SR5 Tundra (sold)
• 2006 Solara SLE Convertible (sold)
• 2008 FJ Cruiser - TRD Edition
  #149 (permalink)
Old 03-23-2009, 09:59 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
You ever find the problem?
25 yrs with TOYOTA
  #150 (permalink)
Old 03-23-2009, 10:46 AM
2004 Toyota Tundra,
My daughter had a 93 Celica GT with an absolutely bulletproof paint job. Likewise for my 99LC. My 2004 Tundra's is decent but my wife's 08 Solara is lacking. Quite a few chips with only 10K miles. Other than that and the underpowered engine,it is a very well built car. If they had used the same V6 in the Solara as they have in the Camry and Avalon, Toyota would have trouble keeping up with the demand.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/camry-solara/67939-solara-questions-ask-me/
Posted By For Type Date
bite line (English to German translation glossary) Automotive / Cars & Trucks,Tech/Engineering This thread Refback 05-13-2008 04:44 PM
2006 Solara Convertible Windscreen updates and Nav System JoesSolara Camry-Solara 21 02-19-2008 06:21 PM
Toyota Announces Pricing For 2007 Camry Solara nhparrot Toyota, Scion & Lexus News 0 05-30-2006 02:24 PM
Questions questions questions. Johnny_boy02 Tacoma 13 11-19-2005 05:39 AM
A Few Questions @v@lonm@n Camry 8 09-06-2005 08:53 AM
Interior fit & trim questions (Sequoia) LSUMBA Interior & Exterior 6 01-28-2005 10:10 AM
