Go Back   Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
Camry-Solara General discussion forum for the Toyota Camry-Solara.
This is a discussion thread titled "Surging '99 Solara", within the Camry-Solara forum, part of the Cars & Vans Forums category.
Old 08-24-2006, 10:46 PM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2004 Toyota Highlander Limited AWD,
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX
THarms's Photo Albums
Last Online: Yesterday 11:34 PM
THarms is on a distinguished road.
Default Surging '99 Solara
Mustang (or anyone else that has some advice...)
My wifes '99 Solara SLE (3.0L V6) has this weird problem... The car idles fine, accelerates fine and runs great on the hwy... but when you are driving in town between 20-40mph, with the engine turning between roughly 1500-2100rpm, the rpm's tend to surge then relax to the point where it feels like you are pumping the accelerator about 1/2" then letting off (I don't know how else to describe it). Its not a real fast jerk, just a pulsing surge but its bad enough that its really annoying when driving around town.
I've recently did a basic tuneup (cleaned the MAF sensor, cleaned the throttle body, changed spark plugs, new air filter, new fuel filter, etc.) which made it idle perfectly. But it still has that engine surging/pulsing in that same rpm range.
My hunch is that the MAF sensor and/or oxygen sensor(s) are in the process of failing... but I don't have any error codes (atleast yet). Before I start throwing any more money at it, I thought I'd see if anyone else has seen this problem.
2001 Sequoia Limited (Family SUV)
1999 Solara SLE (wife's car)
1995 T100 4x4 (my toy)
Old 08-25-2006, 12:54 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Albums
Last Online: Today 10:19 AM
mustang67408 will become famous soon enough.mustang67408 will become famous soon enough.
Default Re: Surging '99 Solara
Is the fuel tank 3/4-full?
I have a few ideas depending on your answer.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
Old 08-25-2006, 08:36 PM
THarms's Avatar
The level of fuel in the tank does not seem to have a noticable impact... although the other day the tank was very low (<1/4 of a tank) when I was driving it and the surging was very noticable.
Old 08-25-2006, 09:29 PM
2002 Toyota Tundra,
Darn, thats shoots that idea.
I'll keep thinking about it.
Have you tried disconnecting the egr valve and see if that helps?
23 yrs with TOYOTA
K.I.S.S.
Old 08-25-2006, 11:20 PM
THarms's Avatar
Disconnected the wire sensor plug to the EGR valve and took it for a test drive. The check engine light came on about 2 blocks from my house... Took about a 5-mile loop around town and it seems the surging has gone away. Stopped off at home and reconnected the sensor plug and the surging returned (check engine light stayed on, but loaned my OBD scanner to my dad a few weeks ago so can't check the code or reset the computer).
From this, I assume that I have a bad EGR valve that needs to be replaced. Is it ok to drive the car with the EGR unplugged for a few days until I can pick up a new one from the dealer?
Thxs for you help!
Old 08-26-2006, 02:46 AM
2002 Toyota Tundra,
I dont think it is the EGR valve.
I THINK it is the EGR POSITON SENSOR. See attachment.
They are known for failing and giving false readings.
Unplug it, remove 3 nuts and lift. Its that easy to change.
You probably have a code p0401 and maybe another. Its ok, you set it when you disconnected the EGR Position sensor. It wont hurt anything with the engine light on, just leave everything plugged in, until you can replace it.
PM sent
23 yrs with TOYOTA
K.I.S.S.
Old 08-29-2006, 01:07 PM
THarms's Avatar
Tested the EGR position sensor with my digital test meter. Ohm reading was ~5.2 so it was out of the 1.5-4.2 range suggested in the attachment.
Picked up a new sensor at the dealership (~$35) and it took me about 10 minutes to install. Car runs again like new... it evens idles better now.
Thxs again!
Old 08-29-2006, 02:42 PM
2002 Toyota Tundra,
Glad you were able to fix it yourself .
You know how those dealership people are
23 yrs with TOYOTA
K.I.S.S.
Old 09-16-2006, 06:40 PM
Dealer : Toyota Scion of El Cajon
1998 Toyota Camry
CharlieWilson's Photo Albums
Last Online: 01-07-2007 11:29 AM
CharlieWilson is on a distinguished road.
Thanks for your help. I have a 98 camry that had the same symptoms. I took it to the dealer and they said my spark plug wires were arcing ($46). I got those replaced (Pep Boys $200), but the symptoms did not improve. I disconnected the EGR vacuum hose (As you suggested) and saw the symptoms disappear. I tested the Vacuum Control Valve (VCV or "that purple round thing") and it was faulty. After replacing it ($60), the problem persisted. I then replaced the EGR position sensor (As you suggested) even though the ohm meter reading was 4.26k which was still barely within spec. (The new sensor cost $50 from the dealer and measured about 3.0k). The problem is gone!
Old 09-18-2006, 08:00 PM
2002 Toyota Tundra,
Another satisifed customer
23 yrs with TOYOTA
K.I.S.S.
Old 03-19-2007, 11:17 PM
Dealer : Mark Miller Toyota
1999 Toyota Camry
Fishtech's Photo Albums
Last Online: 03-27-2007 08:32 PM
Fishtech is on a distinguished road.
PM sent
Can you provide me with the attachment? I am having P0402 and P1411 errors on my 99 Camry. Do you think it could be the same thing?
Old 03-20-2007, 11:22 AM
2002 Toyota Tundra,
Yes, i think it is probably the same problem as long as your camry is a V-6
23 yrs with TOYOTA
K.I.S.S.
Old 03-20-2007, 01:32 PM
PXLpainter's Avatar
Dealer : Carson Toyota Scion
2006 Toyota Camry-Solara V6 SLE Convertible
PXLpainter's Photo Albums
Last Online: 11-30-2008 11:31 PM
PXLpainter is on a distinguished road.
Mustang - thanks for your technical expertise here! Greatly appreciated!
Old 03-25-2007, 04:45 PM
Dealer : Hudiburg Toyota Scion
1997 Lexus ES300
Larryr's Photo Albums
Last Online: 03-28-2007 11:54 PM
Larryr is on a distinguished road.
Hey this was my problem exactly. Did what was said and it cleared it up. Will buy new postion sensor tomorrow. Thanks- The internet is a wonderful thing and thanks for this great web site.
Larry R
Similar Threads for: Surging '99 Solara
2006 Solara Convertible Windscreen updates and Nav System JoesSolara Camry-Solara 21 02-19-2008 06:21 PM
1st Generation Solara thecarguy Camry-Solara 14 08-09-2006 03:24 PM
Toyota Announces Pricing For 2007 Camry Solara nhparrot Toyota, Scion & Lexus News 0 05-30-2006 02:24 PM
2003 Toyota solara subwoofer wmondy Audio & Stereo 0 05-15-2006 09:40 PM
Changes for 2007 Solara? T0626N Camry-Solara 5 04-25-2006 11:09 PM
