I lost my wifes spare key to her 2004 Solara. I still have the daily key she uses, which is black (I think this designates it as a Master? Is this correct) We also have her valet key. I ordered two keys from ebay that came with two sets of instructions. One set said for 1998 + Toyota, Lexus. The otehr set of instructions said for 2002 + Toyota, lexus. I have tried both, and can get neither to work. I am assuming I am supposed to use the 2002 + instructions, but I have also read on here to try different ones if the instructions did not work. Anyways, I am going off of using the instructions that require cycling Ignition from On to Off 5 times, opening Drivers Door six times...
When people talk about the security going off to indicate the key has been programmed, what is the light doing prior to this? Is it staedy light, or a flashing? Mine begins flashing after I insert the new key, and never stops. Also, Also, I have seen conflicting information about when you insert the new key, whether you turn to the on position while it is being programmed, or if you just insert it and leave in the off position.
I appreciate any information I can get. Also, I saw some talk about possible 2004 + not being able to be programmed outside of the dealer. Any truth to this?
Blayne
Current
2006 Tundra SR5 4X2 Double Cab, Limited Slip, Pioneer DEH-9800BT Blue Tooth Deck, Retrax Cover. 2008 Avalon Touring - 12 Speaker with Bluetooth, Sunroof, Traction Control.
Past: 2004 Solara Se Sport 6 cyl, 1990 Corvette Convertible 6 Speed, 1998 Taurus, 1995 Chevy Caprice Wagon LT-1 V-8, 1999 Ford F-250 Diesel, 1993 Pervia LE, 1986 Chevy Caprice, 1989 Honda Prelude 4WS, 1972 Chevy Impala Convertible, 1993 Mustang Special Edition Convertible, 1985 Jeep Cherokee, 1983 Camaro.
Hmmm. I am not sure how anyone would help, considering when I contacted the manufacturer of the key I purchased said they did not make one for the 2004 Solara. They said it was dealer only. Thanks.
Current
"the manufacturer of the key I purchased said they did not make one for the 2004 Solara. They said it was dealer only."
Harsh, if I told you the state was building a Golden gate bridge between IL and MO would you believe that? Moral of the story is everything you are told isn't always the way it is..........
Please refrain from soliciting services unless you are a qualified vender for TS... especially when the services are not particularly legal.
