Go Back   Tundra Solutions Forum > Cars & Vans Forums > Camry-Solara
Camry-Solara General discussion forum for the Toyota Camry-Solara.
This is a discussion thread titled "Need info on installing Short Ram Intake", within the Camry-Solara forum, part of the Cars & Vans Forums category.
Old 01-15-2007, 01:48 PM
Dealer : Performance Toyota Memphis
2004 Toyota Camry-Solara
AUburf's Photo Albums
Last Online: 04-01-2007 12:43 PM
AUburf is on a distinguished road.
Default Need info on installing Short Ram Intake
I bought a Weapon-R Dragon Intake, and I need some help installing it. It came with a few directions, but if anyone has any info on tools I will need or helpful hints, it would be much appreciated.
Car Info:
Toyota Solara '04
3.3L V6
Old 01-15-2007, 06:15 PM
PXLpainter's Avatar
Dealer : Carson Toyota Scion
2006 Toyota Camry-Solara V6 SLE Convertible
PXLpainter's Photo Albums
Last Online: 11-30-2008 11:31 PM
PXLpainter is on a distinguished road.
Default Re: Need info on installing Short Ram Intake
Well - not sure about the Weapon-R but the Injen was pretty straight-forward for me.
You have to remove the OEM airbox completely - make sure you tie-off and cap any unused hoses and be carefull of the sensor that goes back on the intake. Be sure to plug back in all hoses your intake requires - only one actualy functions on the Injen - but there's a couple dummy plugs on the side that get connected as well.
Now the CP-e guys have more electronics to deal with - but we won't go there!
Good luck!
Jeff
Old 01-16-2007, 11:49 PM
Well, i got the intake successfully installed except for two 4mm hoses that wouldnt fit in the splitter they gave me (i'll get one from Lowe's). And now my Check engine, VSC, and Trac OFF, lights all came on. While i expected the check enginge light ot come on, is there any reason that the others came on?
Old 01-16-2007, 11:52 PM
PXLpainter's Avatar
Actually, if everything is hooked-up right and/or capped-off correctly, you shouldn't get any CEL or other warnings after the install.
Did you remove the Neg terminal from your battery while you did the install?
If not - try removing it for at least 30 min. and reconnect to reset the ECU.
Old 03-03-2007, 04:24 AM
Lightbulb Re: Need info on installing Short Ram Intake
So i finally got fed up with those lights, and hot glued some rubber caps on the end of the extra hoses, and the lights magically went off! Good thing toyota directly relates an air reading from a hose to my traction control and my vehical stability :P
Old 03-05-2007, 12:19 PM
PXLpainter's Avatar
Ahhh - so the W-R doesn't have caps or posts to put the hoses on then? Weird!
The Injen has "dummy" posts for the extraneous hoses that don't get reconnected, so it looks like they're actually connected to the body of the intake.
Glad you resolved your issue! That's a design problem with that brand as far as I'm concerned!
Similar Threads for: Need info on installing Short Ram Intake
Gibson Muffler Questions? HotRod8 Towing 18 04-25-2007 11:29 PM
Short ram Intake? AAHTANK 1Gen-Tundra 2 10-30-2006 11:54 PM
Tundra Ranked SGull 1Gen-Tundra 101 10-15-2004 10:19 PM
Ram air intake??? silverTRD Engine & Drivetrain 3 01-21-2004 09:26 PM
AEM Brute Force Intake Tour Writeup- LONG Genthar Engine & Drivetrain 21 11-10-2003 07:25 PM
