Originally Posted by kass178
Could you tell me where in the engine compartment the EGR valve is located? I am having the same problem with my 99 Solara.
DO you have a 4cyl or V-6?
Here are the diagrams for both.
The 4 cylinder does not have a POSITION SENSOR only the V6.
25 yrs with TOYOTA
