Re: Manual trans trans fluid?
Yes, you can still change the oil in the trans. 5 speed manual.
Oil grade:
API GL-4 or GL-5
Viscosity:
SAE 75 W-90
Capacity:
1.9 liters (2.0 US qts, 1.7 lmp. qts)
Fill and drain plug :
Torque: 39.2 N·m (400 kgf·cm, 29 ft·lbf)
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
