Old 07-13-2007, 02:26 PM
Dealer : Frontier Toyota
1995 Toyota Corolla
Last Online: 04-07-2009 09:01 PM
edhalfdead is on a distinguished road.
edhalfdead's Photo Albums
Default Check engine light malfunction
Two days ago the check engine light came on in my 95 Corolla 1.8.
When I tried to pull the codes by jumping the TE1 and E1, nothing happens.
The check engine light comes on but no codes flash. Not even the steady flash of system ok.
Has anyone else had this problem?
Does anyone know how to fix?
Thanks in advance
Old 07-13-2007, 05:24 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: Check engine light malfunction
does the engine light come on with the key on the "ON" position? Is the check engine bulb good?
if it is are you sure you made contact in TE1 and E1
25 yrs with TOYOTA
Old 07-17-2007, 10:59 PM
1995 Toyota Corolla
Thanks mustang67408,
Thats what happens when you have your father-in-law hovering over your shoulder trying to help since he's "done it so many times before", plus the Autozone picture has it backwards also.
It gave a code of 71 which is the egr system, so I'm going to check it out.
Again, thank you, and I'll post back with my results.
Friends help you move...
Real friends help you move bodies.
Old 07-18-2007, 12:06 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Glad you didnt have to trace that circuit too
Let us know
25 yrs with TOYOTA
Old 04-05-2009, 10:19 AM
Last Online: 04-05-2009 11:11 PM
throttle100 is on a distinguished road.
throttle100's Photo Albums
hi
i have the same problem with my corolla 1997.But i tried with the key "on"
position.
First i turn the ignition switch to "on".After i put a jumper between te1 and e1(i'm sure to put it on the right pin of the test connector).
But the check engine lamp stay on without blinking.
Did i forgot something.
Thanks
Old 04-06-2009, 09:52 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Originally Posted by throttle100 View Post
hi
position.
Thanks
The jumper wire will NOT work on a 97.
TE1 & E1 are for setting timing only. You're going to need a scan tool to read your codes.
25 yrs with TOYOTA
Old 04-07-2009, 08:20 PM
1995 Toyota Corolla
Sorry for the long delay in replying. Got a code 71 - egr system operation malfunction. Tested system and had to replace the egr valve. Check engine light came back a few days later and drove me nuts for a while since testing all the other components tested o.k.
Finally tucked my tail and went to a friends mechanic that said the vsv is usually the problem. Told him that it tested o.k. and left the car in his care. He called back 2 days later saying he replaced the vsv and no more check engine light.
$75 well spent. Passed emissions test with better than average results. Fuel economy jumped from 230 to 300 miles per fill up.
I humbly ate crow and re-positioned myself on the ladder of success. Damned stubborn bullheaded Aries...
Old 04-07-2009, 09:01 PM
1995 Toyota Corolla
Default Last Post
Thanks to all here at Tundrasolutions.com for the help.
I probably won't be back since the car was sold and replaced with a Chrysler 300C.
Hemi 5.7 liters of tire spinning, shove you back in your seat, gotta keep my right foot in check fun. So much for fuel economy.
But I am looking at an older 2005 Tundra because I like the access cab, even though the rear seats are useless except for grocery bags.
So for now, talk to you later...Ed
Grr Check Engine Light @ 87550 Miles. 90k Service? el_madmaster 1Gen-Sequoia 8 02-24-2007 09:10 PM
2003 Matrix Check Engine Light psint Corolla Matrix 4 01-26-2007 10:49 PM
Check Engine Light? vegasgreed Engine & Drivetrain 22 07-31-2006 08:33 PM
A/T Oil Temperature Light & Check Engine Light wi_shuaige 1Gen-Tacoma 0 07-03-2006 12:20 AM
Check Engine Light @ 5000 miles? oldirtyhughes Engine & Drivetrain 3 02-20-2004 08:38 PM
