Old 07-21-2007, 02:42 PM
Dealer : Roswell Toyota
1999 Toyota Corolla
Last Online: 07-16-2009 07:25 PM
DukeCityHank may have some regrets.
DukeCityHank's Photo Albums
Default '99 Corolla Power Locks Going Crazy
The power locks are supposed to lock when the car engine is started and then unlock when the engine is turned off. My problem is that the power locks unlock the doors at any time; when I'm stopped, when I'm driving, even when the car is turned off. I'll lock the car with the fob and come back at the end of the day and the doors are unlocked. I can't find any pattern, it seems totally radom. I've taken it to the dealership twice and it never does it while there; so they say and look at me like I'm crazy. Anyone had this problem or heard of it before?
Old 07-21-2007, 11:29 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 177
mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light.
Default Re: '99 Corolla Power Locks Going Crazy
Its a fairly common problem.
1. One of the door switches is not functining properly.(shorting to ground, telling the door ECU (Integration relay) to open the doors.
or
2. There is a bad ground at connector (I12)(front of inside fuse box, orange connector)
or
3. It needs an INTEGRATION RELAY (its mounted to the back side of the fuse box under the drivers side dash). <----MOST COMMON
These are the 3 most common problems
25 yrs with TOYOTA
RENTAL VEHICLES
Old 07-22-2007, 10:25 PM
1999 Toyota Corolla
Thanks for the info.
I can handle the first one, but how difficult would 2 and 3 be to fix myself?
Old 07-23-2007, 08:26 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 177
The second one is not to bad as long as the wires are ok.
They just need to be cleaned, but if they are BAD. Then the wires need to be replaced. That involves cutting and soldering in new wires and a connector.
The 3rd is just a matter of removing and replaceing the Integration relay. It mounts to the back of the fuse box inside the vehicle. (drivers side). Someof the dash pieces have to be reove to gain access to the back side of that fuse box, mostly time consuming and pricey.
25 yrs with TOYOTA
RENTAL VEHICLES
Old 07-25-2007, 04:43 PM
1999 Toyota Corolla
Any idea how much money we're talking about here for the parts?
If I go to the dealership and explain the problem and ask for an integration relay will they know what I am talking about?
Old 07-29-2007, 10:40 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 177
Been on vacation
Pm sent
25 yrs with TOYOTA
RENTAL VEHICLES
Old 07-11-2009, 05:49 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 177
Ya, that used to be a common issue with Corollas.
Most of the time it was either
1: a bad door switch (on pillar and door closes against it)
2: bad ground in a junction connector near the drivers side fuse box
3: Bad integration relay
If you e-mail me mustang67408@cox.net
I will send you some pdf's , that you might be able to use to diagnose this.
Let me know
Thanks
victor
25 yrs with TOYOTA
RENTAL VEHICLES
Old 07-11-2009, 05:51 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 177
PM sent to DCH
25 yrs with TOYOTA
RENTAL VEHICLES
02 Corolla - Passenger Power Window Failing fjtrder Corolla Matrix 5 09-16-2007 09:53 AM
04 AC tundra power locks 42GAMI Electrical & Computer Systems 4 07-21-2007 11:32 PM
Toyota Announces Prices For 2008 Corolla and Corolla Matrix TS Support Toyota, Scion & Lexus News 0 07-15-2007 07:38 AM
LS 600h L Hybrid Sedan: The Ultimate Lexus TS Support Toyota, Scion & Lexus News 0 05-02-2007 04:44 AM
Power Washing the Engine?! Are you CRAZY?! rxvcgiii Engine & Drivetrain 22 01-08-2007 01:48 AM
