08-17-2007, 11:05 PM
Assistant Administrator
Last Online: Today 07:30 PM
10
OK, Now what did I do?
OK.
I went to install Satellite Radio in my 2K2 Corolla. When I get it all put back together, and reconnect the battery, strange things began to happen.
The whole dash started blinking like the Hazard lights were turned on which they weren't. It stopped after about 30 seconds but sometimes started doing it again; seemingly at random. I can hear the sound of a clicking noise coming from the area left of the steering column. The car can start OK (sometimes the blinking will come back on; sometimes not.) The turn signals, radio, cigarette lighter (that I tapped for power the for Sat. radio; it doesn't work, naturally ) and probably other things don't work either.
I suspect I blew a fuse somewhere (it was getting dark and too difficult to work) but the blinking thing has me mystified.
Any thoughts?
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor , Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog__________________________________________________
08-19-2007, 12:25 AM
Last Online: 10-13-2007 10:30 AM
0
Re: OK, Now what did I do?
Check the fuse, all listed items run in acc or run position of the key.
The strange flickering sounds like either broken wire or the flasher was tapped into.
May need to check the fuses under the hood but probably in the car behind the little compartment on the left of the dash.
1999 Corolla VE-B, 5spd, 270,000+ KM
08-19-2007, 06:02 AM
10
Originally Posted by
glow-plug
Well, it turns out I did blow the cig-lighter fuse. But after two attempts to install two different Audiovox XM XpressR Satellite Receiver units (both were factory defects) I said the hell with it, and put it all back together.
It is working fine now. Back to the drawing board.
Salty Dog
08-19-2007, 12:04 PM
0
How about tapping off the radio wiring as it has switched power and hot, dash light control etc? Or at least replicate that wiring.
Are you making this a permanent install or removable?
08-19-2007, 01:19 PM
10
glow-plug
It will be permanent once I get it done.
Why can't I tap off of the cig-lighter? It is switched also.
Salty Dog
08-19-2007, 01:56 PM
0
Should be able to, where did you tap the power?
08-19-2007, 02:41 PM
10
glow-plug
The cig-lighter.
Salty Dog
08-19-2007, 03:54 PM
0
Are you using a cig plug or pulled the wire?
Cyberbilly
The cig-lighter.
08-19-2007, 07:54 PM
10
glow-plug
I removed the console, and tapped into the wires for the cig-lighter. I wired in a second cig-lighter socket, so I can just plug the XM unit straight in, and keep everything hidden behind the console.
Salty Dog
08-21-2007, 03:16 PM
0
It seems strange the issue you had with cig lighter.
I wonder if the XM radio power wires are reversed or if Toyota flips the wiring, did you happen to verify the polarity with a meter?
"I removed the console, and tapped into the wires for the cig-lighter. I wired in a second cig-lighter socket, so I can just plug the XM unit straight in, and keep everything hidden behind the console."
08-21-2007, 04:10 PM
10
glow-plug
The polarity of the cig-lighter(s) are correct. Maybe the power supplies for the XM unit were wired bass-ackwards internally, which could explain a few things.
I figured out the myterious blinking problem. It was the aftermarket keyless entry box that had a loose connection, The Corolla itself seems to be OK.
Salty Dog
08-21-2007, 07:44 PM
0
Does the XM come with a cig adapter or is to be wired in from the factory?
08-21-2007, 08:28 PM
10
glow-plug
It comes with a cig adapter, but what I plan to do on my Corolla what I did on my Tundra. I'm going to tap a new cig adapter socket onto the back of the built in one, and plug the XM adapter into the second one (and the whole mess will be hidden inside the console.)
Salty Dog
08-22-2007, 04:46 PM
0
Don't forget to post your up dates.
I'd like to know how you made out.
Was pulling the console apart straight forward, any hidden screws or clips?
Linear Mode
© Copyright 2009 All rights reserved. TundraSolutions.com.
Other trademarks and brands are the property of their respective owners.
Use of this Web site constitutes acceptance of the TundraSolutions.com User Agreement and Privacy Policy.
Custom vBulletin Skin By
v7web.net
