Old 09-05-2007, 07:21 AM
Dealer : Germain Toyota Scion of Sarasota
2003 Toyota Tundra,
2007 Toyota Corolla
Last Online: Yesterday 08:18 AM
PapaPS is a splendid one to behold. PapaPS is a splendid one to behold. PapaPS is a splendid one to behold.
PapaPS's Photo Albums
Default horn
My wife is not too happy with the corolla horn.........can I put a camray horn in its place? and will it fit or will it need to be modified? Thanks
Old 09-05-2007, 08:39 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
Default Re: horn
Can you post a photo of the horn or the electrical connector? Other Toyota models' horns will probably plug in but I'd like to see what your Corolla's looks like.
Old 09-06-2007, 06:21 AM
2003 Toyota Tundra,
2007 Toyota Corolla
Default Re: horn
I don't have a digital camera..........I priced the camray ones and they want $60 plus........I am going to ck polarity on it this evening.........I know on my 80 it was a live horn that got grounded to go off..........don't know about the newer cars........I might need a relay and a hella horn..........
Thanks tho
Old 09-06-2007, 06:18 PM
Dealer : Toyota of Hopkinsville
2007 Toyota Corolla LE,
- Other - 2004 F-150 Supercrew
Last Online: 10-13-2009 04:05 PM
mcc371 is on a distinguished road.
mcc371's Photo Albums
Default Re: horn
Here's what I replaced mine with. They were $9.99 at Harbor Freight. They will get someone's attention.
Old 09-06-2007, 08:13 PM
2003 Toyota Tundra,
2007 Toyota Corolla
Default Re: horn
Was it a straight hook up or did you need to put in a relay ?
Old 09-06-2007, 08:47 PM
Default Re: horn
The air horns came with a relay. They only cost 9.95 but I see Harbor has raised the price to $14.99 now. I took out the screw on each side of the top of the grill and popped it out for easy access. The relay has four connections. Plug the horn wire into one, run one to the ground. Then one to the battery and another to the horn compressor. I didn't have to drill any holes. I mounted the compressor to the center brace where the hood latch is. There was already a hole there, and I mounted a horn pointing down on each side of the grill area where there were already holes.
The only thing else you need to buy is some wire at least 14 gauge, some crimp on ends for the wire and you need to put a fuse between the battery and the wire that goes to the compressor or connect the wire to an existing 30 amp fused circuit.
Old 09-07-2007, 06:40 AM
2003 Toyota Tundra,
2007 Toyota Corolla
Default Re: horn
That definetly is an option........I know this is an opinion question, but do they sound cheezy? The last ones I put on a car (15 to 20 years ago) were loud but cheezy sounding...........on my 80 I put cadillac horns........they would scare you.
Old 09-11-2007, 03:45 PM
Salty_Dog's Avatar
Assistant Administrator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Yesterday 09:52 PM
Images: 578
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
Default Re: horn
I installed one of these in my Corolla.
Wolo Bad Boy Air Horn
The only thing I had to do was run a ground wire, and a short extention for the factory horn wire. I also had to replace the 5 amp horn fuse with a 10 amp.
It really gets your attention now.
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 09-11-2007, 04:10 PM
2003 Toyota Tundra,
2007 Toyota Corolla
Default Re: horn
is it loud and clear?
Thanks
Old 09-11-2007, 04:21 PM
Salty_Dog's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Images: 578
Default Re: horn
Thanks
Oh yeah. With a distinctively European sound. It'll scare the living bejeezus out of anyone close by.
Salty Dog
Old 09-11-2007, 05:04 PM
2003 Toyota Tundra,
2007 Toyota Corolla
Default Re: horn
Thats funny as that is one of the horns that I was looking at.......GOOD DEAL....... Thanks
Old 09-15-2007, 06:52 AM
2003 Toyota Tundra,
2007 Toyota Corolla
Default Re: horn
Well I did the horn last evening.....I applied the wolo bad boy to the corrolla............I used the motor cycle relay that came with it , to protect the cars wiring........That S.O.B. is loud , and it has a good sound to it. The wife was in the house 125 feet away and she promptly came out to inquire if that was her new horn?.......We are both pleasently pleased with it.......I utilized holes already there, with one just needing a slight widening. A good clean hook up.
MCC371........I meant no disrespect with my question
Old 09-15-2007, 07:39 AM
Salty_Dog's Avatar
2001 Toyota Tundra,
2002 Toyota Corolla
Images: 578
Default Re: horn
Glad you like it. I'm thinking about DUAL Wolo Bad Boys for the Tundra (since I can't afford air horns right now).
Salty Dog
Mod: Train Horn Install Complete w/PICS wileetundra Tundra 85 09-17-2008 07:55 PM
Turn off the auto door lock after ignition start. bondoman Electrical & Computer Systems 18 07-12-2007 12:37 AM
hello from new member amd Q: sensitive horn crixtopher Sienna 2 07-04-2007 02:44 PM
2003 Sequoia Keyeless entry remote programming troubles... OHIOFJ40 1Gen-Sequoia 7 05-07-2007 03:14 PM
anyone install an air horn in their tundra? gatorwire Aftermarket Products 16 09-30-2006 06:41 PM
