Re: Corolla
I have an '07 Corolla LE and an '02 Prerunner 4 cyl. The Corolla is the same width inside as the Prerunner. I'm 6'2" and 275 lbs. and have plenty of room in the Corolla. The little Corolla has all the power you need. Very quick getting up to speed when you have to pull out in traffic. Nice on the interstate too, but if you get too close behind the big trucks, it will try to wander all over the place. You can make a U turn in 1/3 the space required to turn the truck around.
They put the steering wheel too far away. If you slide the seat back to give yourself some leg room, you can't reach the steering wheel. That's the only complaint I have with mine.
