2001 corolla catalytic converter
Hi I have a 2001 corrola. Recently I had the check engine light come on with code 0420, catalyst system fault. I decided to make sure all the litle things were done. I did a lucas fuel treatment. Cheanged the plugs and air filter. I even decided to change the 02 sensors the car had over 100,000 miles so I guessed it couldn't hurt. No Luck. Looks like I'm going to have to change out the Cat. Only problem is that it appears to be welded in. I don't weld but I have friends that do. They said they would rather have me pull the whole exhaust pipe with the cat then do the welding underneath. I was looking and it appears that the muffler is welded on but I can't really see any place other than the exhaust manifold off of the engine to unbolt the pipe. I have a haynes manual but it doesn't give diagrams of all of the different configurations possible. Does anyone have a diagram picture or idea of how this exhaust cat combo run together? Has Anyone run into this before? Hope some one can help. Thanks
Thanks
