Old 11-05-2007, 01:15 PM
Dealer : Bill Penney Toyota
2004 Toyota Corolla
Last Online: 11-21-2007 10:34 AM
tgrindrod is on a distinguished road.
tgrindrod's Photo Albums
Default 2004 Rotor replacement
has any one replace the front brake rotors on the 2004 corolla?
They don't just sit on the wheel studs like most. It appears that the rotor is bolted directly on the hub.
What do I need to remove them?
Thanks
Old 11-05-2007, 03:35 PM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 10-05-2009 12:31 AM
mral1515 is on a distinguished road.
mral1515's Photo Albums
Default Re: 2004 Rotor replacement
No they do sit on the studs (floating rotors). At times they will get stuck due to some rust or road grime. First make sure the caliper braket is off. Take one of the lug nuts and put it back on. Turn the wheel where you can hit the inside of the rotor with a rubber mallet and it should come off. Good Luck.
Old 11-05-2007, 10:19 PM
bri bri is offline
Dealer : Carlson Toyota
2003 Toyota Tundra 4x4 SR5 Access Cab
Last Online: 08-25-2009 11:32 PM
bri is on a distinguished road.
bri's Photo Albums
I had to go with a little more than a rubber mallet to get mine off, more like a BFH. They really do stick if you live someplace they use salt on the roads in the winter.
Old 11-06-2007, 07:49 AM
mral1515's Avatar
2007 Toyota Tundra,
Ok well you know what I was talking about.
Old 11-20-2007, 03:19 PM
2004 Toyota Corolla
Thanks for the help. I had to really hit them hard to get them off but they did come off. Sometimes a bigger hammer is just what the doctor ordered.
tgrindrod
