Old 12-05-2007, 09:01 PM
Dealer : Quality Toyota Scion
Last Online: 11-03-2009 08:40 AM
crfoot is on a distinguished road.
crfoot's Photo Albums
Default wierd corolla sound!
Have a 2006 ce automatic with 37000 miles on it. Just recently when I start it in the morning and put it in reverse, it makes a wierd growling noise. The noise seems to come from the center console area. It only happens when it's cold and it's the first start up of the day and in reverse. I don't accelerate in reverse, only idle. As soon as i put it in drive or neutral it goes away!! Anybody???? Thnx
Keith
Old 12-16-2007, 12:14 AM
thumbster's Avatar
Moderator
Dealer : Capitol Toyota
2005 Toyota Corolla,
2007 Toyota Tundra 5.7 RC SB SR5 Sport
Last Online: 11-15-2009 01:12 AM
thumbster is a splendid one to behold. thumbster is a splendid one to behold.
thumbster's Photo Albums
Default Re: wierd corolla sound!
My wife's car did the same thing, but it ended up going away. I traced it back to the spring loaded exhaust flange at the front cat. I took it to the dealer since it was under warrenty, but they couldn't duplicate it. Haven't heard it ever since.
Old 12-19-2007, 06:51 PM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
Sounds like an exhaust vibration. Could even be the cat. shroud. Mine did this too.
The cat. and shrould is located under the center console, when yu go into reverse th engine shifts slightly and is normal...but as a result the exhaust will shift as well. If the Integrity of the exhaust is compromised in any way , there will be a shudder or loud vibration as the pipes or cat or shroud hit the chassis.
Just some ideas.
LT
Old 12-19-2007, 06:56 PM
LifeTech's Avatar
worn engine and transmission mounts will also cause the exhaust to shift more than it should.
LT
