Go Back   Tundra Solutions Forum > Cars & Vans Forums > Corolla Matrix
Corolla Matrix General discussion forum for the Toyota Corolla and Toyota Matrix.
This is a discussion thread titled "08 corolla 5 speed grind?", within the Corolla Matrix forum, part of the Cars & Vans Forums category.
Old 12-19-2007, 04:34 PM
Dealer : Dorschel Toyota
2008 Toyota Corolla le 5 speed,
- Other - 91 mr-2 turbo,
2004 Lexus RX330
muleman's Photo Albums
Last Online: 09-25-2008 08:54 AM
muleman is on a distinguished road.
Default 08 corolla 5 speed grind?
I have a 08 corolla le 5 speed. With 500 miles on it. When the tranny is cold (sitting for atleast 8 hour or more) The tranny with gring going it to 3 gear. It just started this about 100 mile ago. Any input?
It is about 30deg here. Rochester ny.
Old 12-19-2007, 05:44 PM
LifeTech's Avatar
Slummin'
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
LifeTech's Photo Albums
Last Online: 09-28-2008 10:38 AM
LifeTech is on a distinguished road.
Default Re: 08 corolla 5 speed grind?
I would consider changing to a Synthetic Hypoid gearbox lube of the correct OEgrade and viscosity.
I had similar issues in very cold weather.
It worked really better in all my Toyota standard trans 5-speeds.
The cold weather is just where yu will benefit from Synthetic Hypoids.
Since it is under warranty ,yu can just let the Dealer Figure it out. First thing is to check the Oil Level!!!!
Does the full range of shifting feel stiff and slow when throwing gears at very cold temps? Shifter feels stiff???
Hopefully the fluid level is not low for whatever reason...being an 08 and all.
LT
Old 12-19-2007, 09:19 PM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: 09-25-2008 02:36 AM
Only Toyota for me is on a distinguished road.
LT
I've almost posted the same complaint about my 08 5 speed. Third gear is thee worst in this car. Even when warm, i think it should shift smoother than it does.
I have full range of shifting feel and it don't feel stiff. It's just when you go into third gear is when it feels like it's grinding.
I think i'm going to switch to full synthetic in mine right away.
Thanks for the heads up.
Oh, my brother has the same exact car and it does the same thing. Must be the fluid they put in em that's different.
My 94 camry (built in Japan), didn't feel this way at all.
Old 12-19-2007, 10:59 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
kathyricks's Photo Albums
Last Online: 07-26-2008 11:33 PM
Mobil 1 75W-90 synthetic is notorious for causing notchy shifting and grinding in Toyota manual trannys. So are conventional hypoid GL-5 gear lubes although they are not as bad as Mobil 1 synthetic.
A GL-4 (NON-hypoid) gear lubricant will reduce grinding. Pennzoil makes a product called "GL-4 80W-90 Gear Lubricant" but it's only available in 5 gallon pails.
Nissan makes a GL-4 gear lube in quarts so you might try a Nissan dealer. Ditto for Hyundai and Mazda.
Lastly, if you can afford it, RedLine makes a MT-90 75W-90 GL-4 gear lubricant for about $10 a quart specifically for manual transmissions. Toyota owners of all kinds from owners of 1970's Celicas to modern day Toyotas reports markedly easier shifting action with this lube. There is some concern about whether or not it adequately protects transmission bearings from wear because it does not contain traditional sulfur-phosphorous anti-wear additives, but so far the transmission in one of my Toyotas has run it for 100,000+ miles without a problem.
Old 12-20-2007, 05:02 PM
2004 Lexus RX330
Well The tranny shifts fine into 3rd but lets out a grind (when cold). I am going to switch to red line after break in (car has 500 miles on it.) But the dealer is goin to get it first. I am sure they will tell me that they can't duplecate the problem lol. I will tell them to keep it till they can. Becuase it does it every time I drive it in the moring and when I get out of work (after 8-9 hours). Ps I have been babying the hell out of it to trying to get the best mpg I can. So far I reached 44.6 and it is winter here in rochester ny. =)
Old 12-20-2007, 07:18 PM
Let us know what the dealer says, will you?
That is damn good mileage.
I have yet to do a lot of hiway driving, and the best i've seen is 36.2 in mixed driving on the first tank. I now have about 2000 miles on it, and i'm running 5w30 mobile one synthetic & OEM filters. I get the filters from trdparts4u.com for like $30 a ten pack w/ free shipping, & no tax.
Not bad. I figure the car should pay itself off in about 2-3 years, just in gas savings alone.
Plus i can keep my other nice rigs in the garage where they stay clean in these wet, cold winter months.
Old 01-02-2008, 05:19 PM
2004 Lexus RX330
Ok the dealer has had it for 1 week and to my suprise can't duplicate the problem. I told them the first 2 times to keep trying but they still can't get it to grind. ( I am sure it is sitting in the parking lot the whole time=). So I am going to pick it up tomorrow with nothing fixed. I did bring it in for my free oil change and had them put my customer suplied mobil 1 in it @ 1000 miles. I am going to switch to redline when i get home.
Old 01-06-2008, 05:39 AM
2004 Lexus RX330
Ok I just picked up my car and the next day it did it again. So I recorded a small video and I am going to give the dealer a copy.
Old 01-13-2008, 05:12 PM
tacomatrdsport2591's Avatar
Dealer : Fairfield Toyota
- Other - '87 Corolla FX16 GTS
tacomatrdsport2591's Photo Albums
Last Online: 06-05-2008 08:30 AM
tacomatrdsport2591 is on a distinguished road.
Yes, it is quite obvious. I was looking at another thread with a similer transmission situation, and they discussed changing their gear oil, and many reported a big improvement in the transmission. There are many products out there that may help your situation. So ask around, keep posting here, and let us know how everything goes. DEFINITELY show the video to your dealer, that is your proof right there that there is a problem. Good luck, and keep us updated!
"Close your mouth before you chew."--Marie Barone....."Close your mouth before you talk!"--Frank Barone
Old 01-14-2008, 07:22 PM
2004 Lexus RX330
Do you have a link to the other thread????????
Old 09-01-2008, 02:20 AM
2009 Toyota Corolla,
2006 Toyota Corolla LE 5-speed
My eBay melloski1's Photo Albums
Last Online: Yesterday 10:43 PM
melloski1 is on a distinguished road.
Talking Re: 08 corolla 5 speed grind?
Use BG Syncroshift 2 full synthetic GL-4 75w-80 for your manual Corolla. You will thank me in person...Changed my gear oil with my first oil change on my '09 S and it is the smoothest Crayolla (lol) on the block!
JMJ
Old 09-06-2008, 12:29 AM
I've been running Amsoil 75w90 Sever gear lube in the diff now for about 10k miles and it's not helped the 3rd gear grind much at all. It shifts quite smoothly in all other gear's and some of the time even 3rd when hot. But when cold it grinds quite badly. Come to find out this lube has some friction modifiers in it which is not good for a tranny, and can cause notchy shifting.
I just talked to my amsoil rep, and he suggested the Manual trans gear lube ( MTG ) which is a GL-4 lube, not a GL-5. Since my owners manual calls for either, i just ordered some MTG and will put it in as soon as i get it.
Will post updates to let you all know the difference.
Kathyricks...........can you elaborate on what you know about the GL-4 lubes you suggested?
