Go Back   Tundra Solutions Forum > Cars & Vans Forums > Corolla Matrix
LinkBack (4) Thread Tools Display Modes
  4 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 04-20-2008, 06:19 PM
EastAmwellMike's Avatar
Dealer : Muller Toyota
2000 Toyota Tundra,
2009 Toyota Corolla
Last Online: 01-04-2009 06:02 PM
EastAmwellMike is on a distinguished road.
EastAmwellMike's Photo Albums
Default 2009 Corolla 1.8L 2ZR-FE - Oil Filter Location
Does anyone know where the oil filter is located on the 2ZR-FE 1.8L engine on the new 2009 Corolla?
Old 04-21-2008, 08:59 AM
currybob's Avatar
Dealer : Sunny King Toyota
2009 Toyota Camry HV,
2009 Toyota Tacoma PreRunner Crew Cab,
2009 Toyota Corolla White LE
Last Online: 07-21-2009 09:18 AM
Images: 9
currybob is on a distinguished road.
currybob's Photo Albums
Default Re: 2009 Corolla 1.8L 2ZR-FE - Oil Filter Location
I haven't looked yet for mine but on an older model of mine it was underneath on the passenage side in front of the engine block.
Bob
2009 Tacoma PreRunner Crew Cab. Wife's Car
2009 Camry Hybrid, Mine :
2008 Harley Davidson Screaming Eagle Road King-My Bike
2005 Harley Davidson Deluxe-Wife's Bike
1998 Honda Accord EX (Daughters, but I bought it)
2009 Corolla LE (Other daughter but she's paying for most of it)
Photos located at http://community.webshots.com/user/currybob
Old 04-22-2008, 06:41 PM
longwoodklon's Avatar
2001 Toyota Tundra,
2005 Toyota Sienna
Last Online: 11-06-2009 08:35 PM
Images: 9
longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light. longwoodklon is a glorious beacon of light.
longwoodklon's Photo Albums
They use a cartridge style now, not conventional spin on, right?
/Mike
2001 2WD Silver Tundra: 4x4 TRD springs, Daystar 1", Carson AAL, red/blue Bilsteins, 265/75 Revo's, IS kit(minus bumper) and rims(hand polished), RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. 185k miles and counting......
Old 04-23-2008, 07:48 AM
currybob's Avatar
Images: 9
Not to my knowledge, I got some filters when I got the car and they are the same spin on as before.
Bob
Old 04-23-2008, 07:45 PM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: Yesterday 02:28 AM
Images: 44
Only Toyota for me will become famous soon enough.
Bob
The 08 corolla is spin on, but i have been told the 09's are the cartridge style.
It's possible they give you filters for the 08 instead, especially since you're having a hard time finding it.
Old 04-24-2008, 06:46 AM
currybob's Avatar
Images: 9
Thanks for the info, I will have to look into this. I was hoping the would put it on top like they did my wife's FJ.
Bob
Old 06-02-2008, 12:49 PM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: Yesterday 09:58 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
It is located in the same location as the 09 2.4 engine. It is a very small spin-on type seen from under the vehicle. It is tucked up under the Black plastic Intake Runners(on 1.8's) on the passenger side.
It is easy to get to, but yu will need a lift to get at it. Yu don't need to remove any splash shield.
Yu cannot see/grab or remove this filter from the top!!!
LT
Old 06-02-2008, 02:27 PM
Toyotaterritory's Avatar
Preferred Dealer
Dealer : Joe Myers Toyota
- Other -
Last Online: 10-19-2009 12:06 PM
Images: 5
Toyotaterritory is on a distinguished road.
Toyotaterritory's Photo Albums
REPLACEMENT
CAUTION:
  • Prolonged and repeated contact with engine oil will cause removal of natural oils from the skin, leading to dryness, irritation and dermatitis. In addition, used engine oil contains potentially harmful contaminants which may cause skin cancer.
  • Precautions should be taken when replacing engine oil to minimize the risk of your skin making contact with used engine oil. Wear protective clothing and gloves. Wash your skin thoroughly with soap and water, or use a waterless hand cleaner to remove any used engine oil. Do not use gasoline, thinners or solvents.
  • For environmental protection, used oil and used oil filters must be disposed of at designated disposal sites.
1. DRAIN ENGINE OIL
(a) Remove the oil filler cap.
(b) Remove the oil drain plug and drain the oil into a container.
(c) Clean and install the oil drain plug with a new gasket.
Torque: 37 N·m (377 kgf·cm, 27 ft·lbf)
2. REMOVE OIL FILTER CAP ASSEMBLY
(a) Using SST, loosen the oil filter cap 4 revolutions, align the cap ribs vertically, and drain the remaining engine oil in the oil filter cap.
SST: 09228-06501
Set a container below the oil filter cap assembly before loosening the oil filter cap.
(b) Remove the oil filter cap assembly.
(c) Remove oil filter element and O-ring from the oil filter cap.
Be sure to remove the O-ring (for the cap) by hand, without using any tools, to prevent damage to the groove for the O-ring on the cap.
3. INSTALL OIL FILTER CAP ASSEMBLY
(a) Clean the oil filter cap threads and O-ring groove.
(b) Apply a small amount of engine oil to a new O-ring and install it to the oil filter cap.
(c) Set a new oil filter element in the oil filter cap.
(d) Remove any dirt or foreign matter from the installation surface and inside of the engine.
(e) Reapply a small amount of engine oil to the O-ring of the oil filter cap assembly. Align the cutout in the oil filter cap threads 90° to the grooves in the oil filter bracket and temporarily tighten the cap.
Make sure that the O-ring does not get caught between the parts.
(f) Using SST, tighten the oil filter cap assembly.
Torque: 25 N·m (255 kgf·cm, 18 ft·lbf)
SST: 09228-06501
NOTICE:
  • After tightening the oil filter cap assembly, check for gaps between the installation surfaces.
  • Do not remove the oil filter bracket clip when installing the oil filter cap assembly.
  • Do not cross thread the oil filter cap assembly.
4. ADD ENGINE OIL
(a) Add fresh engine oil and install the oil filler cap.
Engine Oil
Oil Grade
Oil Viscosity (SAE)
  • ILSAC multigrade engine oil
  • 0W-20
  • 5W-20
Capacity
Item
Standard Condition
Drain and refill with oil filter change
4.2 liters (4.4 US qts, 3.7 lmp. qts)
Drain and refill without oil filter change
3.9 liters (4.1 US qts, 3.4 lmp. qts)
Dry fill
4.7 liters (5.0 US qts, 4.1 lmp. qts)
5. INSPECT FOR OIL LEAK
Ken Sanders
866-374-5769
www.toyotaterritory.com
Old 06-25-2008, 12:18 AM
- Other - '85 GMC C2500,
2006 Toyota Corolla LE 5sp,
2009 Toyota Corolla Loaded S 5sp
Last Online: 10-27-2009 11:29 PM
melloski1 is on a distinguished road.
melloski1's Photo Albums My eBay
Thumbs up Re: 2009 Corolla 1.8L 2ZR-FE - Oil Filter Location
It is a cartridge filter located on the passenger side. I will post the part number tomorrow, work for a local Toyota dealer.
JMJ
Old 06-27-2008, 11:34 AM
There seems to be a little confusion on the 2009 Toyota Corolla/matrix with the 1.8L I4 oil filter. Seen lots of forums, threads and blogs about the oil filter and it's location. The oil filter cartridge is located on passenger (right) side of the engine next to the pan. It is a cartridge stlye, Toyota part #04152-YZZA6. Hope this helps!
JMJ
JMJ
Old 06-30-2008, 12:44 AM
LifeTech's Avatar
Correcting my above post..... 2009 1.8 Dual VVT-I Enigine is a Cartridge Element not spin-on.
Yu need a standard filter CAP wrench to remove the sump cover. Yu replace the "O" ring every OCI.
It is much easier a cartridge to replace than on the 3.5 V6 08 like the on the '08 Highlanders.
Old 04-05-2009, 10:19 PM
Banned
Last Online: 05-27-2009 11:05 PM
cookiedough1 may have some regrets.
cookiedough1's Photo Albums
For the 09'' Corolla, the above is correct being a cartridge filter with the same location as mentioned above. Must lift the car up either by jack or ramps to get underneath to remove oil filter cap to get at the cartridge filter. It cannot be any worse than the poorly designed 07' on up Tundra's having to take off 8 bolts holding on the entire skid plate just to get at the oil filter housing. Whomever thought of this stupid idea at Toyota should be fired. It is not extremely difficult, just a pain in the butt and very time consuming not to mention on the new tundra's the oil filter canister is very hard to get off even after cranking over 1/2 way off the threads the canister is very hard to remove still - maybe just my truck, but still ticks me off.
Old 08-14-2009, 09:34 AM
Last Online: 09-01-2009 02:54 PM
marc.deese is on a distinguished road.
marc.deese's Photo Albums
how do you drai the oil out of the filter before removal of same ?
LinkBack to this Thread: http://www.tundrasolutions.com/forums/corolla-matrix/131698-2009-corolla-1-8l-2zr-fe/
Posted By For Type Date
Info.com - how to take a oil filter off corolla 09 - www.Info.com This thread Refback 10-08-2009 09:44 PM
I found the Oil Filter. - Page 2 - PriusChat Forums This thread Refback 06-21-2009 11:45 AM
Re: oil fillter - Car Talk - Comcast.net Community Forums This thread Refback 06-11-2008 07:46 PM
oil fillter - Car Talk - Comcast.net Community Forums This thread Refback 06-11-2008 01:58 PM
