Old 07-27-2008, 12:35 AM
Dealer : Hanlees Hilltop Toyota Scion
1998 Toyota Corolla
Last Online: 07-28-2008 11:29 PM
TakuSkan is on a distinguished road.
TakuSkan's Photo Albums
Default Remove driver side window motor on '98 Corolla?
Can anyone lead me through the process of removing the driver side window motor on '98 Corolla? I've got the door panel off, but getting the motor out looks tough.
From what I've read, it entails pulling the glass out, pulling out a 'regulator' assembly which I can see down in there, and removing a few other things before the motor can finally be removed.
Any help on this would be greatly appriaciated.
Old 08-01-2008, 10:17 AM
Dealer : Covington Pike Toyota
1999 Toyota Corolla
Last Online: 08-01-2008 10:17 AM
emma120 is on a distinguished road.
emma120's Photo Albums
Default Re: Remove driver side window motor on '98 Corolla?
To remove the window motor you first have to take off the inside panel of the door. Once that is done unbolt the the window regulator and the motor. After this is the tricky part and you might want someone else there to help. You have to remove the window itself. To remove the window you must unbolt the two bolts at it's base. Someone to hold the window while you do this is nice. After the window is unbolted you can pull the regulator and motor out through the door. The motor can then be unbolted from the regulator. Getting this out can be as hard as getting it back in so expect it to be a hassle.
