91 Corolla, no power to dash lights, a/c, radio and starter.
1991 Corolla won't start, no power to dash lights, a/c blower, and starter. Checked starter and replaced ignition switch........no change. The brake light and radio would go on and off at times before this happen. Any ideas??? Thanks!
Re: 91 Corolla, no power to dash lights, a/c, radio and starter.
Originally Posted by pintnight
Did you checked the fuse?
Yes. I get power up to and through the ignition switch but still dash lights etc...,
Which fuse exactly by the way........dont want to over look anything?
Check Fuse "AM1" it is a 40amp fuse link & 100amp fuse link, they are the ones in the fuse box attached to the positive battery cable at the battery.
24 yrs with TOYOTA
