Re: oil cumsuption problem
Some have had good luck with the ECU re-flash, others have had good luck switching to a 30 weight. I have been using RP 5W-20 with no consumption issues as of YET. However I will switch to a 30 weight if I start seeing a loss in oil. It's worth noting that the ECU flash might not cure the problem, and will yield lower MPG's.
No oil on stick after only 2,000 miles is really not good. A visit to the dealer should be your first step.
2008 5.7L DC Limited TRD / Slate Metallic with Grey Leather interior / fully de-badged --- 19.2mpg over 450 miles averaging 57mph!
