Old 10-17-2005, 12:26 AM
supritdeol's Avatar
Dealer : Dublin Toyota Scion
2006 Toyota Corolla
Last Online: 03-25-2008 01:39 PM
supritdeol is on a distinguished road.
supritdeol's Photo Albums
Default running a power inverter
I want to run a power inverter in my corolla to hook up a PS2. The problem is that in the car it says 12V 120 Watt max. I wanted a 400watt power inverter. Can i use it?
The PS2 says that it uses 93W 120V
Old 10-17-2005, 06:49 AM
imjin's Avatar
ΜΟΛΩΝ ΛΑΒΕ
Dealer : McGeorge Toyota
Last Online: 11-20-2009 08:24 PM
Images: 66
imjin is a splendid one to behold. imjin is a splendid one to behold. imjin is a splendid one to behold.
Send a message via AIM to imjin imjin's Photo Albums
I say go for it. The worst that can happen is you'll blow a 12v lighter fuse.
Old 10-17-2005, 10:58 AM
supritdeol's Avatar
2006 Toyota Corolla
i talked to toyota dealer today and they told me that the ciggeratte lighter is limited to 15 amps, so i think im going to run it for now and then hardwire it this weekend.
Old 10-18-2005, 08:48 AM
Dealer : Toyota of Greenville
2005 Toyota Tacoma
Last Online: 06-21-2009 08:49 PM
mdbrjb is on a distinguished road.
mdbrjb's Photo Albums
Default Inverter
Hi,
Voltage times amperage equals wattage. So, 400 watts at 120 volts would be about 3.33 amps. Say 4 to be on the safe side. 120 watts at 12 volts would be about 10 amps (probably 15 amp fuse).
Should be no problem at all.
Bob
Old 10-18-2005, 11:34 AM
supritdeol's Avatar
2006 Toyota Corolla
Thanks for your help. I bought a 400 watt inverter from kragen for $39.99 with $10.00 rebate, and it ran fine. The only thing i noticed was that i was getting horizontal lines running down my screen when i was playing PS2, but i dont think thats from the inverter.
Old 08-19-2009, 08:02 PM
Last Online: 08-19-2009 08:02 PM
Tommy1 is on a distinguished road.
Tommy1's Photo Albums
Default Re: running a power inverter
AS for the inverters out there...the best power inverters are (imho) made by power bright. the power bright inverters are great. i like this place for them: Batteries by Battery Tex: POWER BRIGHT Batteries
you'll see they have the cables too...but generally good stuff for good prices.
hope that helpz
-t1
Tapping power from overhead console - Tacoma Don Presten Audio & Stereo 3 03-02-2005 11:54 PM
Power for PS2 Jhamilton1 Audio & Stereo 5 01-20-2005 09:42 PM
Head Unit Power nhparrot Audio & Stereo 0 03-28-2002 02:01 PM
Power sliding back window nhparrot Electrical & Computer Systems 0 03-28-2002 01:17 PM
