Old 10-17-2005, 11:17 PM
Last Online: 05-08-2008 08:29 PM
cwirth is on a distinguished road.
cwirth's Photo Albums
Default Windshield washer does not work
The windshield washer does not work any longer on my '05 Matrix. The rear window washer does however. I checked the manual and it seems that there is only one 15A fuse that is used for both the windshield and rear window washer which is ok. Does the washer resevoir have two pumps, one for each glass? Not sure where to look for the problem.
Old 11-10-2005, 06:47 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Yes each one has its own pump motor (front and rear motors).
If the fuse is good make sure you have 12v at the pumps (LIGHT BLUE WIRE)
Then have somone activate the pump with the switch and check for GROUND at the other wire(BLUE w/YELLOW STRIPE)front motor only.
If you have 12v and a ground signal from the switch, the pump is bad or maybe the squirtes are plugged with wax or debris. If you have no 12v then there is an open circuit you must trace down.
If there is no ground you have a open circuit in the wiring from the switch or a bad switch.
Good luck
25 yrs with TOYOTA
Old 12-17-2007, 09:48 PM
Dealer : Westbury Toyota
2003 Toyota Matrix
Last Online: 12-17-2007 09:48 PM
smarrazzo is on a distinguished road.
smarrazzo's Photo Albums
Default Re: Windshield washer does not work
BTW: Where is the motor for the windshield pump.
Is it under the washer resevoir? I have no squirts front or back?
But it has been cold the last few days.
Old 12-18-2007, 12:21 AM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Yes, it is in the washer resovoir.
25 yrs with TOYOTA
Old 12-18-2007, 01:08 PM
Dealer : Performance Toyota Memphis
2004 Toyota Tundra
Last Online: 11-17-2009 01:47 PM
buglao is on a distinguished road.
buglao's Photo Albums
I don't a matrix but make sure your washer tank have plenty of fluid in there front and rear. I have seen some model car have front tank for windshield and rear tank for rear window. If your pump are working ok it be the washer tube clogged somewhere. Good luck
Old 12-19-2007, 07:15 PM
LifeTech's Avatar
Dealer : Penn Toyota Scion Ltd.
2006 Toyota Matrix XR SR w/TRD addons,
2001 Toyota Avalon XLS,
2006 Toyota Highlander Limited 4WD Nav RSE
Last Online: 11-09-2009 12:35 AM
LifeTech will become famous soon enough.
LifeTech's Photo Albums
4-5 PSI of compressed air (no more!)to clear the rear lines and the rear window jets would be another way of checking for a clog or jamb in the line motor or jets.
LT
Rear washer pumps rarely burn out. could be the switch or +12v side
Jets do clog, and see if yu can hear the pump working. This is very easy thing to do first.
Hose lines do come apart especially if the fluid froze up in the lines using weak/poor washer antifreeze. This has happened to me.
LT
Dynolock Does Not Work! atrdnut Audio & Stereo 21 02-25-2007 11:35 AM
Getting my windshield replaced/front painted, I miss my truck!!! rivalred Tacoma 6 11-16-2005 06:47 AM
Windshield Scratched??? Jonesie Interior & Exterior 7 07-28-2005 02:58 PM
Came across these pics of moded Taco. Some nice work done. Tiggyboot Tacoma 5 04-04-2005 09:40 AM
Rust under windshield DJJ Interior & Exterior 8 05-05-2004 11:31 AM
