The GEO is a COROLLA IN DRAG LOL
I would make sure the timing belt hasnt slipped. (advanced timing will ping all the time, even with premium)
I would also make sure the EGR system is working and not plugged. EGR cools the combustion chamber to help reduce emissions and PINGING.
Are you sure it isnt an exhaust leak, corrollas are known for cracking exhaust manifolds.
Hope this helps
25 yrs with TOYOTA
