Hi all,
as the title says the rear defogger is dead in my wife's 1998 corolla.
When I push the defogger button, i can hear the relay click and the indicator on the dash comes on. But the defogger does not heat up.
So I checked the 2 fuses in the dash and they are both good.
I pulled off the rear trim panels by the rear window and the main lead is still connected to the defogger. The ground lead is also connected. There is no voltage on the hot lead when i turn on the defogger.
I checked the continuity at the rear window to make sure it wasn't a bad solder joint.
I noticed that the dash light did not come on when I turned the defogger on and I had the 40 amp main fuse out. I think this means that the relay is good, since the dash light seems to be energized only when the relay is on. And the dash light works when the 40 amp is in.
sigh.
so my best guess is that the main wire is broken somewhere, hopefully in the dash and not in the rear fender (which was replaced after a fender bender).
does anyone know where the defogger relay is in the dash? a wiring diagram would be a major assist here!
thanks for any help.!!!!
Bill
