Originally Posted by cantfigureitout
i have an intermitant problem with my 1989 corolla. it runs fine, then suddenly it runs poorly, looses all power, blows black smoke and almost dies. then it comes back to normal and runs fine. the entire episode might just last a few minutes. for the life of me i cant figure it out.
Is ir EFI or CARB? Late 89= EFI/ Early 89= Carb
Can you pull a code? Check engine light?
If it is CARB the first thing I would say , is that it is the AAP Diaphram closing and shooting extra fuel into the engine or the diaphram is leaking.Usually the plug in cylinder #4 turns black or fouls.
If it is EFI, then I would be looking at the EFI TEMP SENSOR or the Coil in the distributor.
25 yrs with TOYOTA
