Go Back   Tundra Solutions Forum > Cars & Vans Forums > Corolla Matrix
Unichip.com
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 04-19-2006, 10:39 PM
Last Online: 04-21-2006 02:48 PM
smeta is on a distinguished road.
smeta's Photo Albums
Default Stripped spark plug thread
Ok, I don't know much about cars, but here is my situation...
I have a 90 Corolla Wagon w/ 253,000 miles. I blew a spark plug today and the mechanic said the threads are stripped. He tells me that if he puts an insert in to anchor the spark plug, metal shards will be stuck inside the engine and really mess up the car. Is this BS or not? To replace the cyclinder he tells me it will be $1500 (the car is only worth $1400).
TIA!
Old 04-20-2006, 06:48 AM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
Last Online: Yesterday 11:46 PM
Images: 2
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch RitcheyRch's Photo Albums
Default Re: Stripped spark plug thread
They have kits to put a heli-coil in there. Some of the major auto parts stores carry these.
If you dont feel comfortable doing this find a good reputable shop to do the work. When they drill out the cylinder head they will coat the special drill bit and tap with grease to collect the metal pieces.
Old 04-20-2006, 09:40 AM
My husband can do the work, he just hasn't had a chance to look at it yet because I am out-of-town.
Any special instructions for him?
Old 04-20-2006, 12:37 PM
RitcheyRch's Avatar
Fellow Tundra Owner
2002 Toyota Tundra
Images: 2
No real special instructions. If he has installed heli-coils before than he will not have any problems doing this.
QUOTE=smeta]My husband can do the work, he just hasn't had a chance to look at it yet because I am out-of-town.
Any special instructions for him?[/QUOTE]
Old 04-21-2006, 10:09 AM
cupidstoy's Avatar
Dealer : Reliable Toytota
2004 Toyota Tundra,
2003 Toyota Corolla Lola
Last Online: 12-31-2008 06:02 PM
cupidstoy is on a distinguished road.
cupidstoy's Photo Albums
safest way is to remove the head and drill it out. it's more work but not more work then rebuilding the engine if a little piece of metal gets into the cylinder and starts grooving out the wall so it burns oil or worse, causes a hot spot and the piston or rod shatters and goes through the block.
another consideration is why did you "blow" a spark plug in the first place and why did it strip the threads? if the plug was loose, the threads could have "burnt" but the car would have been running pretty badly up till that point. if the mechanic overtightened the plugs last time they were out, that could have stripped the threads and caused the loose plug and then the repairs should be on that person. i realize that may be your husband or may be hard to proove.
anyway, just noting that something else is going on here and the root cause should be found and fixed if the car is worth keeping at this point.
good luck!
2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
Wish list: too long, wife would kill me!
2003 Corolla (bone stock, but well loved and cared for!)
"Expect the impossible."
- JC and the Brothers of Thunder
Old 04-21-2006, 12:53 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Last Online: 07-02-2009 06:39 PM
Images: 153
mustang67408 is a splendid one to behold. mustang67408 is a splendid one to behold.
Great advise, and even if a piece of metal shaving gets into the cylinder they usually just blow out the exhaust.
The grease on the tap usually collects most of the shavings.
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
Old 09-08-2008, 01:27 PM
GlennSmith128
This message has been deleted by Tundradrenalin. Reason: unauthorized ads
LinkBack to this Thread: http://www.tundrasolutions.com/forums/corolla-matrix/61813-stripped-spark-plug-thread/
Posted By For Type Date
Blown sparkplug on Trition V8 (2002) 5.4L 350 XLT - Page 6 - Mombu the Ford Forum This thread Refback 05-21-2009 02:34 PM
Blown sparkplug on Trition V8 (2002) 5.4L 350 XLT - Page 3 - Mombu the Ford Forum This thread Refback 05-15-2008 07:39 PM
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 04:25 PM
Best Spark Plug? tuffloud1 Engine & Drivetrain 20 07-28-2007 09:57 AM
New Plugs nhparrot Engine & Drivetrain 1 10-21-2006 12:14 AM
Spark Plug Gap Discrepancy MikeT Engine & Drivetrain 8 03-04-2006 07:16 PM
Spark Plug???? BT-22 Engine & Drivetrain 4 06-11-2002 09:00 AM
