LinkBack (11) Thread Tools Display Modes
  #16 (permalink)
Old 04-17-2007, 12:12 PM
Dealer : Peruzzi Toyota
2002 Toyota Celica
Last Online: 04-17-2007 08:34 PM
dkuz98 is on a distinguished road.
dkuz98's Photo Albums
Default Re: Corolla 2002 door panel removal
Where can I get a copy of the pdf file listed in this thread? I need information on removing the door panels from my Celica.
  #17 (permalink)
Old 08-11-2007, 10:21 PM
Dealer : Anderson Toyota
2005 Toyota Corolla
Last Online: 08-11-2007 10:24 PM
zoom is on a distinguished road.
zoom's Photo Albums
Hi. How do i find these pdf for the toyota corolla door panel removal?
I cant seem to find the link. Thanks in advance.
  #18 (permalink)
Old 01-05-2008, 06:10 PM
Dealer : Sun Toyota - Edmonton
2000 Toyota Corolla
Last Online: 01-05-2008 06:11 PM
piranhaa is on a distinguished road.
piranhaa's Photo Albums
Originally Posted by Dexterous View Post
For 98-02...
- pop off the armrest on the door carefully by prying and pulling it up, there will be clips holding it in place; then remove the 2 screws behind the arm rest
- remove the mirror interior cover, the triangle piece, it pops off also
- remove the screw behind the door opening handle and slightly push the handle cousing toward the back (or front?) of the car and try to pull it out slightly, you will see a wire rod attached to it, you will need to pry the clip off the wire end so you can pull out (up) the wire from the handle cradle
- remove the visible "screw" head clips from the door panel and pull the door panel away from the door; there are a bunch of clips on the bottom of the panel.
- once the door panel is loose, pull it straight up to loosen from the lip holding it to the door right at the bottom of your window (top of the door panel)
- unplug the harness from your door power lock/window switch
That should do it.
The speaker is riveted to the door, you will need to drill out the rivets if removing the speakers.
Hey... yeh I'm also trying to swap out my speakers for some new ones. When you specify pulling up the arm rest, do you actually mean 'REMOVING' it? If so, how do you detach the clips from the arm rest? I spent like 30 minutes on it, and failed miserably. I can't see you being able to leave the arm rest attached if you are going to rescrew the door panel back on - it seems the clips get in the way.
Thanks
  #19 (permalink)
Old 01-07-2008, 10:51 PM
Dexterous's Avatar
Dealer : Stone Mountain Toyota Scion
1999 Toyota Corolla
Last Online: 01-07-2008 10:51 PM
Dexterous is on a distinguished road.
Dexterous's Photo Albums
The arm rest needs to be removed to get to the 2 screws behind it to release the door panel from the frame. The arm rest can be pulled up carefully with a flat screw driver. The clips are held tight, but you can carefully pull UP the armrest; it will take some effort. There are 4 to 6 clips holding it tight.
  #20 (permalink)
Old 07-07-2008, 10:51 PM
Dealer : Glass Toyota
2000 Toyota Celica
Last Online: 07-08-2008 05:46 PM
fade is on a distinguished road.
fade's Photo Albums
Originally Posted by mustang67408 View Post
Steps 1-11 in the REMO.PDF should get you to the rear speakers in your 01 celica
The DISA.PDF is for the front door.
i dont see the pdf files... am i missing something?
  #21 (permalink)
Old 01-01-2009, 04:48 PM
Last Online: 01-02-2009 03:16 PM
tackleman is on a distinguished road.
tackleman's Photo Albums
Default Re: Corolla 2001 door panel removal
Where do I find the REMO.PDF for the 2001 corolla front door speaker replacement?
  #22 (permalink)
Old 02-11-2009, 03:02 PM
Last Online: 02-11-2009 03:09 PM
jre83189 is on a distinguished road.
jre83189's Photo Albums
hi, im new to this forum, and im trying to download the pdf to remove the window crank on a 2002 toyota corolla from mustang67408 but theres no link, can anyone help me?? Thanks
LinkBack to this Thread: http://www.tundrasolutions.com/forums/corolla-matrix/64642-corolla-2002-door-panel-removal/
Posted By For Type Date
Replacement Speakers, Replacement Sling Back For Freedom Designs Wheelchairs, Replacement Starters For Kohler Magnum 18 Hp Twin Engine - Motorcycleflag This thread Refback 03-06-2009 03:52 AM
How to remove door panel ('99 Corolla)? This thread Refback 04-27-2008 05:01 AM
Search Results for toyota tundra door panel removal This thread Refback 11-22-2007 05:28 PM
How to remove door panel ('99 Corolla)? - alt.autos.toyota | Google Groups This thread Refback 10-26-2007 07:01 PM
How to remove door panel ('99 Corolla)? This thread Refback 10-08-2007 07:35 AM
How to remove door panel ('99 Corolla)? - Car Dealer Forums This thread Refback 10-02-2007 02:43 PM
Celica Forums - Celispeed.com - View Single Post - How to remove door panel ('99 Corolla)? This thread Refback 06-08-2007 03:54 PM
Google Groups: alt.autos.toyota This thread Refback 01-03-2007 03:37 PM
JLA FORUMS - How to remove door panel ('99 Corolla)? This thread Refback 12-30-2006 04:54 PM
Google Groups: alt.autos.toyota This thread Refback 11-18-2006 06:56 PM
Google Groups: alt.autos.toyota This thread Refback 11-10-2006 01:47 PM
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
New Plugs nhparrot Engine & Drivetrain 1 10-21-2006 01:14 AM
2002 Corolla Radio has Security Code?? Stooge Audio & Stereo 1 08-30-2006 05:35 PM
