LinkBack (26) Thread Tools Display Modes
  #46 (permalink)
Old 04-28-2008, 02:29 PM
Dealer : Carousel Toyota
2006 Toyota Corolla
Last Online: 04-28-2008 02:31 PM
manny_elmaravilla is on a distinguished road.
manny_elmaravilla's Photo Albums
Default corolla '06 CE install fog lights wiring
Hello
I have a corolla 06 CE and did not bring the wiring up of the relay or fog lights conectors, I already have the turn signal head fog light switch, if someone can give me reference on the installation and a wiring diagram.
Thank you for your attention
  #47 (permalink)
Old 05-04-2008, 07:03 PM
Dealer : Metroplex Toyota
2006 Toyota Corolla
Last Online: 06-06-2009 12:04 PM
mak618 is on a distinguished road.
mak618's Photo Albums
Default Re: Factory Fogs on '06 are easy
Hi can someone post pictures of how the factory wiring looks like for fog lights ?
I too tried looking for the wires behind the foglight covers on my 06 corolla LE but didnt see anything. I checked the fuse box and the first slot (as per the manual it should be the fuse for fogs) is empty.
Thanks,
  #48 (permalink)
Old 05-04-2008, 07:05 PM
2006 Toyota Corolla
also assuming that my car isnt pre-wired for fogs, what would be the best way to install them ? Is going for the orig toyota fogs the best route to go or just buy the OEM stuff and install them since the wiring has to be put in place any ways
Thanks in advance !
  #49 (permalink)
Old 05-04-2008, 11:52 PM
2006 Toyota Corolla
can any one post details on how seperate switch on the dash connects ?
how many wires does it have. Where do they connect.
I tried searching for diagrams for an after market install, however didnt find one. This is the first time I would be doing this install, any help is appreciated
  #50 (permalink)
Old 08-23-2008, 07:35 AM
Dealer : Larry H. Miller Toyota
2006 Toyota Corolla
Last Online: 08-27-2008 05:14 PM
fidelgp17 is on a distinguished road.
fidelgp17's Photo Albums
Originally Posted by lynxy View Post
NO wires at all. Looked everywhere. Brand new Corolla 2006 CE. Was 12 miles on it when got it. Looked everywhere - no wires. I now that I'm lucky.
There is even nothing between the cabin and the car, the slot for relay is empty, no contacts, just plastic frames.
I don't want to wire it.
If somebody interested in a turn switch, a relay and fog lights can sell all the stuff with discount. all the stuff arives in 2 days.
PayPal only.
DO you still have those fog lights, how much.
  #51 (permalink)
Old 08-23-2008, 07:36 AM
2006 Toyota Corolla
I am interested in buying those fog light, relay and turn switch, how much?
  #52 (permalink)
Old 08-23-2008, 07:42 AM
2006 Toyota Corolla
Originally Posted by 9phil9 View Post
Ok gang, here it is, the news quite a few of you have been waiting for.
If you want to install factory fogs on your '06, and maybe all 9th gen Corollas', here is all you need.
Two lamp assembly's (one right - one left ), a turn signal/headlights/foglights switch, and the fog light relay for the fuse box under the hood.
The factory already installed all the wiring, and most likely the fuse too, for you, so that part of the job is done.
Install your lights carefully so that they are secure, open the hood and pop open the fuse box. Push your relay into it's socket, and close the box.
Drop the hood.
Remove the three screws that secure the two steering column shrouds, (one upper, one lower) then disconnect the plug from the turnsignal switch.
Now depress the plastic locking clip and slide the switch up.
Push the new switch down until it locks in place, and reconnect the plug for the wiring harness.
Carefully replace the two shrouds fastening them with the three screws.
Start your car and turn your new lights on.
Kool, huh?
And so simple I can't believe it.
Now all you have to do is wait for it to get dark, so you can AIM them properly.
Total cost will run you about $300 if you get all the parts new. That is, if you get the lights from a vendor off ebay.
The switch can be had for $125, and the relay is about $50.
Total time to install, should be less than 20 minutes. (If you are sober.)
Hey, don't tell me I don't contribute.
You're welcome.
I am a new member, and I want to ask you where can I buy a fog light with all the things needed to install it that are not really as much as expensive .
  #53 (permalink)
Old 08-23-2008, 07:43 AM
2006 Toyota Corolla
Please help me where can a buy foglight with all the accessories that would fit my toyota corolla le
  #54 (permalink)
Old 10-18-2008, 09:12 PM
Attak998's Avatar
Dealer : Laking Toyota
- Other -
Last Online: 11-09-2009 10:01 PM
Attak998 is on a distinguished road.
Attak998's Photo Albums
So is all you need now the wiring?
Otherwise, I have paypal and would be interested in your switch and relay.
  #55 (permalink)
Old 11-30-2008, 06:48 PM
Dealer : Kerry Toyota
2007 Toyota Corolla
Last Online: 11-30-2008 06:48 PM
jrtimm is on a distinguished road.
jrtimm's Photo Albums
Do you happen to have the part numbers for the relay and the switch?
[quote=9phil9;505951]RKOWALK
I get my parts from these guys.
TRD Toyota/Scion Parts Accessories from Sparks Toyota/Scion
Even if the parts you want are not advertised, that's ok, just send them an email detailing exactly what you want.
They charged me $48 for the relay, and $125 for the switch.
Not too bad compared to what your dealer is attempting to overcharge you for.
  #56 (permalink)
Old 11-30-2008, 06:51 PM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: 11-19-2009 10:28 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Would these relays work? I used them to install factory heated seats in my Tundra, you may have to cut off one of the pins though.
Susquehanna MotorSports - Detail
  #57 (permalink)
Old 01-28-2009, 03:37 PM
Dealer : Don Davis Toyota
2007 Toyota Corolla BLUE CE
Last Online: 05-29-2009 10:56 PM
mdtrdtaco is on a distinguished road.
mdtrdtaco's Photo Albums
Smile Re: Factory Fogs on '06 are easy
For all you guys who want to add fog lamps I will sell you all four factory pieces for $500.00 plus true shipping cost to ship it to you from Texas.
Here is how your pricing will break down.
81210-AA011 LAMP ASSY LIST PRICE $205.66 QTY. 1 YOUR PRICE $142.19
84140-02200 SWITCH AS LIST PRICE $192.28 QTY. 1 YOUR PRICE $131.61
90080-87026 RELAY LIST PRICE $67.93 QTY. 1 YOUR PRICE $46.97
SUB TOTAL $462.96
TAX $37.04
TOTAL $500.00 PLUS SHIPPING
  #58 (permalink)
Old 03-21-2009, 02:26 PM
Last Online: 03-30-2009 07:57 PM
rkenman44 is on a distinguished road.
rkenman44's Photo Albums
I almost installed a foglight kit on a 03 corolla, purchased on ebay. I say almost because I've installed it all the way through to the switch on the dash. Now there is a white plug with a yellow wire that needs a home. I can't locat where the plug installs at. Oh, the foglight kit does not come with instructions.
Last edited by rkenman44; 03-21-2009 at 02:37 PM. Reason: forgot to add car & model
  #59 (permalink)
Old 03-21-2009, 09:17 PM
I found foglights for my 03 corolla on ebay
LinkBack to this Thread: http://www.tundrasolutions.com/forums/corolla-matrix/64686-factory-fogs-on-06-are-easy/
Posted By For Type Date
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 09-28-2009 11:08 PM
Automotive Dealership Marketing, Automotive Dealer Management Systems, Automotive Decals Stickers - Motorcyclechocks This thread Refback 03-08-2009 06:32 AM
MSN Shopping This thread Refback 10-13-2008 08:20 AM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 05-08-2008 12:39 PM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 07-29-2007 11:48 AM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 07-27-2007 08:30 PM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 07-23-2007 02:07 PM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 07-19-2007 11:27 AM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 07-08-2007 07:29 PM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 06-29-2007 01:07 AM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 06-14-2007 03:20 PM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 06-14-2007 02:04 AM
Toyota Corolla Fog Lights - CarSpace Automotive Forums This thread Refback 06-12-2007 08:56 AM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 06-02-2007 07:28 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 04-18-2007 12:39 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 04-09-2007 02:57 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 04-03-2007 01:42 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 03-20-2007 09:32 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 03-09-2007 11:39 AM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 03-06-2007 10:34 AM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 03-05-2007 09:38 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 03-05-2007 04:32 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 03-04-2007 08:11 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 03-03-2007 10:57 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 02-28-2007 04:20 PM
Toyota Corolla Audio - CarSpace Automotive Forums This thread Refback 02-28-2007 12:51 AM
replacing factory deck - need 2nd opinion fullers2oh Audio & Stereo 5 11-29-2005 10:58 PM
Factory theft-deterrent sticker - yours under or over factory tint? 57hotrodvw Tacoma 3 11-14-2005 07:38 AM
Installing factory Nav in 04 Runner. cdoyle Audio & Stereo 2 03-07-2004 07:53 PM
Please help me!!! Factory Restore Audio Prob! Avionix Audio & Stereo 7 01-26-2004 12:45 AM
resettting factory needles on tundra.. Tundrav8yamaha Audio & Stereo 6 01-19-2004 04:45 AM
