Go Back   Tundra Solutions Forum > Cars & Vans Forums > Corolla Matrix
Old 07-19-2006, 12:28 PM
Dealer : Tony Graham Lexus Toyota
1998 Toyota Corolla
Last Online: 09-18-2008 09:03 PM
billmcc64 is on a distinguished road.
billmcc64's Photo Albums
Default Any common problems in the evap recovery system?
Hey folks,
I've had our Corolla in at the dealer for a check engine light.
The first time, they said the gas cap was loose. Hah! It wasn't loose & the CEL came back the next day. I put a new gas cap on anyway, though.
This time they pulled codes P0441 and P0446 off of the computer. They say I need a new vapour pressure VSV and the charcoal cannister is very corroded and should be replaced. This is starting to add up... $$$
Anybody had experience with this one?
And does anyone know where the charcoal cannister is located on the Corolla? I'd like to see 'very corroded' meself before I shell out the extra $200 for a new one.
Bill
Old 07-20-2006, 01:41 AM
Dexterous's Avatar
Dealer : Stone Mountain Toyota Scion
1999 Toyota Corolla
Last Online: 01-07-2008 10:51 PM
Dexterous is on a distinguished road.
Dexterous's Photo Albums
Default Re: Any common problems in the evap recovery system?
Old 07-30-2006, 08:16 PM
1998 Toyota Corolla
thanks! I found it now (I was looking for a cylinder before).
the cannister is mostly plastic, this isn't corroded. but all the metal bits on the top are pretty rusted out.
Bill
Old 08-10-2006, 12:48 AM
Dealer : Falmouth Toyota
2000 Toyota Corolla
Last Online: 09-06-2006 08:40 PM
diyedd is on a distinguished road.
diyedd's Photo Albums
Hi Billmcc64,
Guess you haven't been searching on-line much! Lot's of Toyota owner think there should be a recall, and that Toyota is stonewalling. Seems many, many Toyota Carbon Canister systems fail for various reasons. This seems especially for pre-03 models (after which they relocated the Canister to higher level than gas tank). With all the valves and road-debris back above rear axle-beam, no wonder dirt and water can effect the numerous hose connections and valves.
Anyway, yes OBD codes P0440, P0441, P0446 can all mean dealer replacement of the Carbon Canister. Going rate right now appears $265 for part and another $140 for Labor (if they charge the customary half-hr for OBD analysis). It's a crap shot if they really spot the cause or just know from experience that the Carbon Canister is problematic and replacing usually cures CEL. BTW, I also wasted $8 on new gas cap; that really is sucker move (but everyone feels obliged).
PS - My OBD readout for 2000 Corolla was only P0446, and yes, the replacement of Carbon Canister (which comes with two VSV) did make the CEL stay away. Cost at Dealer was $411 total.
Just try to minimize damage and don't thank Toyota for their premature failed system.
Newer not always better!!
Old 10-05-2006, 12:18 PM
Dealer : Woburn Toyota
2005 Toyota Corolla
Last Online: 05-17-2007 11:15 AM
oliveirakm is on a distinguished road.
oliveirakm's Photo Albums
I've got a 2005 Corolla with 37000 miles and my CEL just lit up. I brought it in and after paying $85 they told me it was code P0456 and I needed a new Charcoal Cannister for $455. He told me it was faulty and it happens; and once I replace I should never have to do it again. To me, it sounds like its a defect but I'm 1000 miles past my warranty so they says its my responsibility. So, no I'm frustrated with the dealer and wonder if I should just have my local garage take care of this.
I guess this is more of complaint vs a question. But I thought I would post just because it seems that this is not uncommon.
Any thoughts?
Old 11-24-2006, 09:46 PM
Dealer : Metro Toyota
1999 Toyota Corolla
Last Online: 12-27-2006 08:11 PM
hontvu is on a distinguished road.
hontvu's Photo Albums
My Toyota Corolla 99 got P0441 yesterday, dealer said no need to have further work up. I feel unsafe with the CEL on all the time.
Toyota extended warranty covers for Toyota Corolla 99?
Old 03-09-2007, 03:52 AM
Dealer : Ourisman Fairfax Toyota
2006 Toyota Sequoia,
2003 Toyota Corolla,
1999 Toyota Corolla
Last Online: 10-05-2009 12:49 PM
swooper77 is on a distinguished road.
swooper77's Photo Albums
This post is probably too late for the original poster, but hopefully it will help others. My fiance's mom had a problem with her Evap canister, so I did a little checking online. This seems to be a common problem and the EPA actually filed a suit against Toyota. It only applies to 1996-1998 models. It extends the warranty on the evap emissions control system to 14 years 150,000 miles.
Unfortunatly my fiance's mom's car is a 1999, so it isn't covered by the extended warranty. Apparently Toyota made some change in 1999 that got around the EPA's requirements, but they didn't actually fix the faulty evap system. So the evap systems on 1999-2003 Corollas still fail prematurely, but are not covered under the extended warranty. Cost my fiance's mom a small fortune to have it fixed.
Other 1996-1998 models including the 4-Runner, Rav-4, Camry, Avalon and a few Lexus models are also included in this extended warranty. You can go to this website for more details. When you call Toyota about this extended warranty, they will deny that it exists. You have to be very persistant and refer them to the website before they will acknowledge it. Good luck.
Toyota Motor Corporation OBD Settlement - Compliance and Enforcement - U.S. EPA
Old 06-19-2007, 08:01 PM
Dealer : City Toyota
2005 Toyota Corolla
Last Online: 07-18-2008 03:13 PM
kj6loh is on a distinguished road.
kj6loh's Photo Albums
Dexterous,
Do you happen to have a diagram of the 2005 Corolla's Charcoal Canister? or is it the same as the diagram you posted?
Old 01-06-2008, 12:39 AM
mhm mhm is offline
Dealer : Metroplex Toyota
2000 Toyota Corolla
Last Online: 01-06-2008 05:44 PM
mhm is on a distinguished road.
mhm's Photo Albums
I own a 2000 corolla with just over 110,000 miles and my CEL light came on as well. Autozone checks the CEL for free, and the same codes came up for the EVAP canister. The problem with the canister is that it lies below the tank, so fluid sits in the canister and damages the inside.
A couple people asked whether it was necessary to get a new one. It is, for a couple reasons.
1. In most states, if your CEL is on, they automatically will not give you a clean smog inspection.
2. The EVAP canister dehumidifies the air in the mixture. So especially in humid climates, its important to keep the air dry.
So, get it fixed, but try to buy the part and do the work yourself.
Once you get it in though, there are a couple of things you can do to prolong its life.
First of all, always get the gascap on at least three clicks. This will prevent the CEL from reading false codes again and will prevent backflow.
Also, NEVER top off your tank. When you do this, the gas is much more likely to backflow past the sensor and into the canister, restarting corrosion and bringing back that CEL.
Hope this helps!
Old 03-23-2008, 09:27 PM
J.D J.D is offline
Dealer : Mississauga Toyota
2005 Toyota Corolla
Last Online: 03-24-2008 09:25 PM
J.D is on a distinguished road.
J.D's Photo Albums
Originally Posted by billmcc64 View Post
Hey folks,
Bill
Hey there,
My 2005 corolla has now been in the shop for the past week as they try to figure out the problem with the evap recovery system. At first they thought it was the charcoal filter. They changed it and it the CEL still came on. Next they replaced the fuel filler neck. I took it hope and 1 day later the engine light came back on.
Anyone else having this problem on their '05? This should be a recall.
Old 06-10-2009, 08:44 AM
Dealer : Toyota of Hackensack
2007 Toyota Rav4
Last Online: 07-01-2009 08:11 PM
njscan is on a distinguished road.
njscan's Photo Albums
We can add a 2007 to the list.. my sister's 07 Corolla's CEL came on. The dealer reset the codes and told her if it comes on again we'll have to get Toyota involved. Fortunately she has the extended warranty and they gave her a 2010 loaner without asking.
Old 08-27-2009, 08:22 AM
Last Online: 08-27-2009 09:25 AM
Steve Jones is on a distinguished road.
Steve Jones's Photo Albums
I've been having the 41 and 46 codes the last couple of weeks on my 99 Corolla. Luckily, I have my own code reader that clears codes. I clear them, they come back within a couple of days. I checked the gas cap of course, as that is what many searches on this show up. This was the first place where I found any estimates on cost. I have just over 200k miles on my Corolla, the only major problem prior to this was I had to replace the starter, pretty easy once I figured out exactly where all of the bolts were. Anyway, has anyone on here done this fix before? I've read on some other sites that there could be a number of components causing these codes. Just looking to see if anyone has done this and how hard it was. I have no doubt that I could do it, but finding the time to do it is the trick.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/corolla-matrix/67204-any-common-problems-evap-recovery-system/
Posted By For Type Date
Had my 2005 Toyota Corolla scanned and these are - FixYa This thread Refback 05-17-2009 11:25 PM
Driveline vibration. nhparrot Engine & Drivetrain 5 01-23-2009 04:21 PM
V6 Engine problems are common???? IntenseNY Engine & Drivetrain 13 01-12-2005 10:49 PM
Tundra Offroad Mods and Tech DevinSixtySeven Off-Roading 15 05-24-2004 10:22 AM
How much bass can be expected from a system with no sub? Agent WD-40 Audio & Stereo 16 01-21-2003 10:47 PM
