Old 08-17-2006, 02:09 PM
Dealer : Earnhardt Toyota
2000 Toyota Corolla
Last Online: 04-26-2007 10:46 AM
chef_m is on a distinguished road.
chef_m's Photo Albums
Question 2000 Corolla - remove door panel when replacing interior door handle?
2000 Corolla base model, no power anything.
I need to replace the interior door handle on the driver's door. Will I have to remove the door panel to do so?
Are there any gotcha's or special tools in replacing the door handle?
Step-by-step instructions would be appreciated, if available.
Thanks in advance.
Old 08-21-2006, 10:40 PM
Dexterous's Avatar
Dealer : Stone Mountain Toyota Scion
1999 Toyota Corolla
Last Online: 01-07-2008 10:51 PM
Dexterous is on a distinguished road.
Dexterous's Photo Albums
Default Re: 2000 Corolla - remove door panel when replacing interior door handle?
No
Philips screwdriver and needle nose pliers.
- remove the screw behind the door opening handle and slightly push/slide the handle cousing toward the front of the car and try to pull it out slightly, you will see a wire rod attached to it, you will need to pry the clip off the wire end so you can pull out (up) the wire from the handle cradle
Old 08-22-2006, 07:54 PM
2000 Toyota Corolla
Piece of cake, just as you said. Thanks so much for the help.
Old 02-22-2007, 05:20 PM
Dealer : Toyota 101
1998 Toyota Corolla
Last Online: 02-22-2007 05:20 PM
mantosridar is on a distinguished road.
mantosridar's Photo Albums
Thanks U. Worked for me.
Old 11-22-2007, 09:21 PM
Dealer : Anderson Toyota
2000 Toyota Corolla
Last Online: 11-22-2007 09:21 PM
Fixitgirl is on a distinguished road.
Fixitgirl's Photo Albums
Chef M
Do you or does anyone else know do you have to purchase the door handle at the dealer or can it be relaced somewhere else?
Old 05-05-2008, 08:41 AM
Dealer : Poway Toyota
1999 Toyota Corolla
Last Online: 05-27-2008 12:40 PM
dwpeat is on a distinguished road.
dwpeat's Photo Albums
Will this procedure be the same for the 1999 Corolla with Power Locks and Windows? I pulled my handle out enough to see the plastic clip and the metal hook, so I'm hopeful...
LinkBack to this Thread: http://www.tundrasolutions.com/forums/corolla-matrix/69527-2000-corolla-remove-door-panel-when/
Posted By For Type Date
bootykika's bookmarks on del.icio.us This thread Refback 05-14-2008 04:45 PM
2000 corolla toyota louie1314 Corolla Matrix 1 08-10-2006 11:27 PM
Removing cupholders PagalDesi4Life Interior & Exterior 20 03-12-2006 04:08 PM
Replacing serpentine belt in 2000 V8 Tundra 4DRSS Engine & Drivetrain 8 11-26-2004 01:40 PM
